Question about Weber Genesis Silver B Grill
Ignite prob I have 3 yr old Silver B Weber. This is first yr I've kept covered outside all winter. (snow & rain, Indiana) Now I'm trying to use 1st time since last fall. When I turn on gas (full tank), open burner valve, ignite spark. Nothing! When I use manual fire lighter just the first (front burner) ignites (other 3 burners don't ignite when valves opened). Is there a method to clean out burners or something? Need new spark igniter?
  • Anonymous Mar 27, 2014
    The barbecue is over 5 years old.It was off and hasnt been used all winter and then when it started to snow the side burnr started to make a clicking sound.
You've got two different things going on.  First - the type of igniter used on your model does wear.  I have had mine for over 10 years and have gone through 3 such igniters - and I grill nearly 3 times per week over the 25 week "grilling" season where I live. Spring for the $12 part and just replace it. The other issue sounds like a clogged cross-over system.  I would remove the burners, including the cross-over bar on the far left side that connects them.  Clean the exterior with a stiff steel/brass brush and the inside with a bottle brush.  Make sure all the holes are clear to allow gas to flow easily - use a wooden tooth-pick to do this to make sure you don't change the size of the holes! Put that baby back together and I think you'll find you'll be good as new!
These grills are great.  Now, if Weber could only fix the uneven heat problem between the left and right side I'd REALLY be happy!  (I wish they would even just admit there IS a problem!)
Good luck and happy grilling.
Posted on May 19, 2008
2006 ford free star when it rains the PCM gets wet and runs rough. Today it has rained for 3 days @ won't turn over. Battery is fine. Only a problem when it rains.
Rain should not affect your car starting. It sounds as if your battery is failing. Put your headlights on and get someone to turn the key with you looking at the headlights. If they dim to a glow-worm, your battery is not powerful enough. Sometimes a cell will fail and although your get 12 volts, you don't get enough cranking amps.
Regarding starting in damp weather, you can try this. Spray all the ignition leads with WD40 and also the inside and outside of the distributor cap. You can also try this which worked for me on an old Datsun that didn't like damp weather. Get some broadsheet newspapers and tape them together to make one large cover for the engine compartment. Make is about 10 sheets thick. Run the vehicle with this all over the winter. When you drive the paper warms and keeps the leads warm. When you park, any moisture in the air goes into the paper and doesn't condense on the ignition system. Make sure the paper is away from moving part like the radiator fan and the exhaust manifold. Check it after your first short drive, it should stay in place.
Dec 02, 2015 | Ford Cars & Trucks
Replacing the crossover ignition system in my weber genesis silver b grill. it has a propane tank. the small metal cover over the spark ignitor has rusted out.
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
May 19, 2011 | Weber Genesis Silver B Grill
2 yr old baby Q new tank was able to get very litle flame then nothing tryed with lighter checked connections Tryed a used mini tank no go The snow is about gone here and would like to get her...
The LP Grill tank's OPD Valve has locked up your regulator. To solve the problem turn the tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose and turn the tank valve on VERY, VERY, SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner and turn it to high. Does the flame height now look correct? If so, you solved the problem.
If it didn't and the grill and tank were stored outside during the snowy winter. The grill's regulator may be frozen. In which case, soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. If that was the problem, gas should start flowing again, in several minutes.
Hope this helped to solve your problem.
Apr 03, 2011 | Weber Grilling
The grill top was open and it rained alot. I am trying to ignite the grill and it won't start. Any suggestions?
try lighting with a match and let it dry out. You may need to blow it dry with an air compressor or canned air.
Aug 10, 2010 | Weber Genesis Silver B Grill
My weber spirit grill, takes 10 or more tries to light, always lit 1st time now last 3 times takes many tries, I put in a fesh tank and still
The area where the igniter strikes the spark probably is covered in grease and needs to be cleaned. Also check battery, and make sure wire is connected and getting good contact.
Jun 09, 2010 | Weber Spirit? E-310
We just had the propane tank checked, reattached
Stick a fan heater next to the burners for a few hours
Or pour some lighter fluid into the burner holes and set fire to it
Make sure you have a long match
Jun 25, 2009 | Weber Genesis Silver B Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Problem with ma ibm thickpad
loose the back of yr ibm if u cant find the cmos battery then u might need to disasemble the whole system carefully under the key board i think thats where th cmos battery will be.
Note removing cmos battery in some systems dont clear cmos password u have to do some additional work to remove yr password. for the battery prob try using a diff battery to be sure what ur prob is.
thank u
May 26, 2008 | Computers & Internet
Weber Genesis Silver B Grill Logo
460 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
