Question about Car Audio & Video
2001 Saturn radio reset after battery change
My girlfriend had the battery replaced in her 2001 Saturn L100 a few months ago. The factory radio has not worked ever since. I verified that it is getting power, as the the clock works and the display lights up etc. I read & followed all the steps in the owners manual and I get an ERR1 message on the display. She has not set the theft deterrent feature on the radio. She said it happened once before when she went for service a couple years ago. She said she took it back to the shop and they did something quick to get it working again.
  • 2 more comments
  • mikes73z Mar 03, 2008
    The radio won't work. It just displays the time.
    No, not working now. I was looking for instruction on the procedure to get it working after a power failure.
    I saw this solution on the Saturn site earlier today. I'm not sure it will work because I'm getting an "ERR1" on the display, not "LOC" or "INOP" an in the instructions.
    That err1 thing was really bugging me. She bought the car used, so it's entirely possible the original owner keyed in a code that we don't know anything about. I'll give these procedures a try this weekend when I see her again.
    Thanks for the good information and your help!
    Mike
    Master:
  • 788 Answers
Check out this thread, especially kdunville's message: http://forums.carreview.com/showpost.php?p=11263&postcount=11
Posted on Mar 03, 2008
  • Dean Joly
    Dean Joly Mar 03, 2008
    Here is a thread that describes the process for a Saturn: http://www.saturnfans.com/forums/showthr...
  • Dean Joly
    The err1 indicates that the theft deterent lock is active, try the procedure to see of you can get a code returned, if it does return a code then call the 1-800 number and get an unlock code, enter the code and your radio should work.
  • 796 Answers
What is happening to it now??
  • isaac johny
    isaac johny Mar 03, 2008
    is it working now or not??
  • isaac johny
    the dash radio module has a small button ,
    by pressing the tuner panel will pop out...showing some connector leads....
    try to clean the dirt off that and replace it again....
    also check if the connector is properly plugged in...it may also due to loose connections..
When the battery is good dash lights come on but no start no cranking of starter
Check battery connections, make sure they clean and tight. Often there is enough connection for a light but not good enough to pull high amp starter.
Apr 01, 2015 | Depo Auto Parts Saturn L100 L200 LW200...
Where is the fuel relay switch on a 2002 saturn L series
You have a fuse / relay box under your hood. My 2002 L100 special edition, 4 cylinder, is located near the battery. You have a relay and a fuse in series. A fuel pump operations check, section 4-3 of the Haynes Saturn L-series 2000 to 2004 manual, you can hear a soft whirring sound for 1 to 2 seconds when you turn the ignition to the ON position. I can confirm mine makes this sound when I do this. Good luck with the fix.
Note, I had a crack in my fuel pump, but I took it to an ex-Saturn dealer 4 or 5 years ago because I did not want to mess with it at the time. They had the part and fixed it in 4 hours, but it also cost me $1000 to replace the fuel pump and install a new fuel filter.
Mar 23, 2014 | 2001 Saturn L-Series
Saturn l100
its blown up-knocking is probably a rod sticking out of the block-cheers Denny
Nov 02, 2013 | Cars & Trucks
I have a 2001 L100 seires Saturn and My service light and the security light both are on and the car wont start. the battery seems to be fine all the lights work i left it alone for a while and it started...
No, the fuel gauge not working wouldn't have anything to do with your not starting problem , probably the gauge is bad . With the SECURITY light lit , anti-theft system problem ! Service light ????? Service engine soon ? Or service vehicle ? With the light's on code's DTC'S - diagnostic trouble codes are stored . Have it checked , don't guess as to what the problem is. This would prevent the buying of un needed parts .
Jun 11, 2017 | 2001 Saturn L-Series
I have the Nikon Coolpix L100 camera and have had it for several months without encountering a single problem. I got a message saying that the batteries were exhausted and it shut down. I replaced the...
I have the same problem with my Coolpix L100. On 27 December 2010 after taking a few shots with flash, using rechargable batteries for one year, it displayed in Hungarian that the batteries are depleted, but after I have recharged them, the camera did not start again anymore, displaying in continue that the batteries are depleted, and it turn off itself after a few seconds. I think that the problem is with the sensor of the camera that should measure the battery status, because even if I had new batteries it desplayed an icon with half battery but I never let it depleted totally so far. Now I am wondering if NIKON will offer free service for it as I have bought it just about 16 months ago in the Romanian DOMO market chain.
Dec 25, 2010 | Nikon COOLPIX L100 Digital Camera
How do you reset a service engine light on 2001 saturn l100?
You will need a OBD II scanner to reset or turn off the MIL (Malfunction Indicator Lamp).
Jun 17, 2010 | 2001 Saturn L-Series
Leaking heating core 2001 saturn L100
mine did same thing. It was just the o-rings on pipes where they slide into heater core simple and cheap fix. do it yourself.
Feb 19, 2010 | 2001 Saturn L-Series
2001 saturn sl, a few days ago, it was sluggish, had trouble shifting (automatic), the other night it kept loosing power, lights dimmed and radio cut in and out now it wont start, if jumped it's fine take...
Have your saturns battery checked out by load testing it. The charging system as well. Most auto part dealers will do this for you....Kragens, Napa, Autozone...Inspect and clean battery cables and terminals, replace as needed.
Good luck..i hope this helps, please rate me a fixya.
Jul 20, 2009 | 2001 Saturn SL
Wiper motor replacement 2001 saturn l100
Steve, You can find information at several web sites. One is All Data but they will charge you for each individual vehicle but Auto Zone will provide most vehicles for free.
Good luck.
Regards,
Jan 21, 2009 | 2001 Saturn L-Series
How do i reset the radio after Re-installation of factory radio?
there is a little button that u push with like a tooth pick or pen
Nov 21, 2008 | 2006 Chevrolet Cobalt
Car Audio & Video Logo
534 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
