Question about Dell Inspiron 1000 Notebook
Cant record in stereo
Can only get my input to record in mono, not stereo??
  • neetah Mar 03, 2008
    have the same problem on my philips freevents laptop
  • 520 Answers
Need more info.what are you trying to input what software do you use to repair.you could try opening volume control,properties.click recording put tick in box for stereomix.
to get to volume control ....click start.all programs ,accessories,entertainment.
Posted on Mar 05, 2008
Stereo only playbacks in mono. it used to play stereo
Stereo is actually two identical amplifiers which when the left and right of a stereo signal is fed into the respective inputs will reproduce the stereo sound through the left and right speakers.
Mostly there is a mono/stereo switch so if only a mono signal is available it is reproduced through both speakers.
You don't make it clear whether the playback is in mono or half a stereo?
If playback is in mono it will emerge from both speakers but the directional element will be absent. If the playback is in half a stereo the sound will emerge from one speaker only or mostly one speaker.
Most common problem is the failure of one of the amplifiers which could be electronic or the failure of any of the various switching usually used in such things.
The amplifiers can be tested by injecting a signal into each amplifier input and will be found satisfactory if the sound emerges from each speaker in turn at a similar volume.
Sep 01, 2017 | Audio Players & Recorders
B2 Pro left stereo channel is Mute
This is not a stereo microphone. There is no left channel. If you are recording into a stereo input, you need to split the input into two mono inputs, and record each channel as a mono track.
Feb 02, 2013 | Behringer B-2 Pro Professional Microphone
How can I transfer recordings from S725 to my pc. I have windows XP
You will need to get a 2.5mm mono to 3.5mm stereo adaptor from somebody like Maplin.
The 2.5mm end of this needs to plug into your earphone jack (mono) on your S725.
Get a ready made cable with a 3.5mm stereo plug on both ends.
Put one of these plugs into your 2.5mm mono to 3.5mm stereo adaptor.
Put the other plug of this cable into the AUX input of your PC.
If you do not see an AUX 3.5mm input, look in or around the area where you would normally
plug your headset. Try checking the manual that came with your PC. Some PCs do not have "AUX" marked on the 3.5mm socket.
Be careful not to have the volume level of the S725 too high as you are testing your setup.
You might damage the Mic input of your PC if you blast too high a level at it.
Next you will need some software like Audacity (Free) to record your tapes.
Have fun but be careful if you are not sure about the connections.
Hope this helps.
Sep 12, 2011 | Olympus Pearlcorder S725 Handheld Cassette...
When I record vocals with stereo setting it always records left more in favour of the right. Is there a way to fix this?
Your microphone is a mono input (one), therefore recording in stereo is not practical. Stereo inputs are left and right (two inputs). Whatever your recording setup or audio workstation, the track you record to from your microphone needs to mono.
Jun 29, 2011 | Samson C03U Professional Microphone
I AM TRYING TO RECORD IN STEREO IN TO THE **** INPUT. IS THIS IN PUT A STEREO IN PUT?
The microphone input is a mono input.
To record in stero you need a USB stereo input adapter.
Please click on this link to this WEB site to purchase :-
http://www.usbgear.com/computer_cable_details.cfm?sku=USBG-X4S&cats=121&catid=121
Aug 19, 2010 | Dell Latitude D510 Notebook
Recording vs880ex - can't hear the headphones in stereo
what you do is treat her like a lady wants to be treated.
touch it
when you input make sure your only putting one device in the hole.
kiss it after your done
Are you recording in mono?
That could be the problem
Jul 21, 2009 | Computers & Internet
Is there a stereo input for the Dell Inspiron 1100 to record?
Yes, the input is stereo BUT you need to configure Audacity to do the stereo capture. Go to File > Preferences. Once in the preferences dialog, go to the third Drop-down menu, and change from MONO to 2-channel stereo. That is.
Apr 27, 2009 | Dell Inspiron 1100 Notebook
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
2 tracks
press F4 to open device panel. there you must be able to select inputs and out puts fromyour alesis interface.
be in stereo or mono(check your alesis specifications to know how many mono and stereo inputs it has.
then when you create a new track on the right side of the sequencer window. you must see a input and uut put routing tab
so if you whant to record voice in one track select the inputs where your mic is plug
create a new track and select the other input
so for shure it will say alesis INPUT 1
alesis INPUT 2
alesis INPUT 3
and so on depending on how many inputs your devices haves.
you say it haves 2. but
are they 2 only in stereo
or two in mono
or one mono+one moni+one mono+mono
for a total of 4 inputs in mono mode and 2 in stereo mode.
i dont know witch device you have so i cant tell.
if you have any questions let me know
Jun 29, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Dell Inspiron 1000 Notebook Logo
91 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
