Question about Kyocera Oystr KX9 Cellular Phone
How do I reset my Kyocear Oystr KX9
My phone won't turn on or charge. When I try to charge it, it displays the hourglass on and off. I'm thinking that perhaps a reset will fix it. But I don't see a reset button or switch. Can anyone help?
jr
To reset it you have to take the battery out for a short time, a minute or so. I am also having problems with mine turning on and charging. I have also heard that the battery life is not good.
Hope this helps some.
Marion
Posted on Apr 23, 2008
Forgot password on virgin mobile kyocera kx9d cell phone
For this problem contact your mobile service provider...
Sep 03, 2011 | Kyocera Oystr KX9 Cellular Phone
My screen went dark, so i can't see anything on it: no phone numbesr, nothing.
IT MAY BE HAVING SCREEN PROBLEM, SO NEED TO NEED TO REPLACE WITH NEW ONE
Dec 15, 2010 | Kyocera Oystr KX9 Cellular Phone
Screen on phone went blank
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 04, 2010 | Kyocera Oystr KX9 Cellular Phone
Forgot password
Call your provider.
http://cellphoneforums.net/kyocera/t300785-i-forgot-my-lock-code-kyocera-melo-s1300.html
http://forums.wirelessadvisor.com/kyocera/14612-codes-for-kyocera.html
Aug 26, 2009 | Kyocera Oystr KX9 Cellular Phone
KX90-125 Kyocera Unlock phone
if you never changed your unlock code it could be the last 4 digits of your phone number or the standard 0000 or 1234. could also be 6 digit code 000000 or 123456 or 654321.
if your changed your lock code you may need to contact your cell phone service provider for the master lock code or phone reset password.
don't forget to have your account info ready when you call.
May 14, 2008 | Kyocera Oystr KX9 Cellular Phone
Spiker
well you are going to have to get a life then HA HA HA HA HA HA H AH A AH
May 12, 2008 | Kyocera Oystr KX9 Cellular Phone
Blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Display black
I hope that when you say blank it means partially lit, with a kind of background, but no image.
This solution is not for an abused phone, as it does not seem to be mechanical, or due to a loose connection. It rather seems like a firmware failure. It will not make your phone usable, instead, it will enable you to retrieve your saved numbers. Once these cheap things start failing they become disposable.
Tried removing battery: No cigar. Tried opening it carefully (under 90 degrees) still no solution.
Here's what worked for me. Phone off, either by powering it down of by having removed the battery.
Get a toothpick, and with the phone CLOSED in the off position, pinch the power-on button and let the phone come on closed. It may not work the very first time, but you should be patient. Once it comes on, you can do just about anything with it until you power it down.
**Make sure you have charged your battery prior to this, since will be spending some time retrieving your numbers**
Good Luck!
Feb 18, 2008 | Kyocera Oystr KX9 Cellular Phone
Kyocera oyster
This phone cannot recieve picture messages because it's not a camera phone. With this phone company only camera phones can recieve picture messages.
Jan 26, 2008 | Kyocera Oystr KX9 Cellular Phone
Kyocera Oystr KX9 Cellular Phone Logo
281 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
