Actually a Scanoe with a square hole in it!!
I have an old Coleman Scanoe (canoe)that we accidentally melted a square hole in from the exhaust from the fireplace vent at side of house.
Is there anybody that can patch and repair this for us.
We are located in Hamilton, Ontario
  • Gary Davd
    Gary Davd May 11, 2010
    Does the Canoe Wash clothes as well???
Ha Ha! Very funny :)
Maybe, I've never tried it.
Is suppose with the gaping hole, it will allow the water in, so if Iput the clothes in the canoe, it will lilkely wash a little.
All kidding aside, since you know Coleman, I just wondered if you would have a referral to someone out this way
Cheers!
Craig
Posted on Mar 03, 2008
I have a really old coleman canoe & the front seat support bars are broken.Any ideas how to repair or where to find replacement parts? Coleman says its discontinued so no parts from them.
Compare with a Pelican canoe, and see if its parts will fit.
Alternatively, make something similar out of aluminum tubing or hardwood.
Do consider if the boat is actually worth fixing. A used Coleman can be found for $250-350, and if you do much canoeing a used (better canoe) can be found for $450-550 in most areas.
Jun 05, 2014 | Coleman Boating
I have a coleman canoe about 1978ish model 5907-719 17 ft. I can't find a replacement center thwart. Any ideas?
Post a picture of what it looks like, if you can.
If it was wood, then just make one. Else make a wooden one to fit where the Aluminum would have been. That is the usual thing to do with older boats, and cost-effective.
If you really care about the canoe, seek out an old one for sale "well used" and buy it as a replacement or for parts. An elderly Colman is not worth a lot, so don;t spend a ton on fixing the first one.
May 24, 2013 | Coleman Boating
Rivets popping out of gunwale
I don't know how big they are, but probably easy enough to replace with a pop-rivet tool ($5-10 for a cheap kit). Else replace with a nut and bolt with the permanent version of lok-tite and/or glue.
It would be wise to find out why it is under strain at that point, but remember these are made of soft plastic and designed so they can stack like garbage cans for shipping (final assembly at store or at home) so it might not be put together quite straight.
Apr 20, 2013 | Coleman Scanoe Canoe
My new Coleman SCANOE sank.
Look up the "Bird Of Prey Canoe Stabilizer" on YouTube. For less than $80 a guy made stabilizers for this model of canoe. I'm looking into buying one and found your post. I have read in another area that people were having issues with it taking on water in the back while using a motor. We mostlly row, so at most I was considering a small trolling motor.
Jan 15, 2013 | Coleman Scanoe Canoe
I can't find any id on my old scanoe, how can i get an id number for it.
I have one from the 1980's and found numbers stamped on the side stern quarter, hard to see
Mar 21, 2011 | Coleman Boating
I need to fix or have fixed a hole in the 'keel of an old green plastic Scanoe, otherwise in excellent condition. I live in Wollongong and local canoe suppliers can't handle the type of plastic in...
hi im not sure if fibreglass repair kit from a car spares shop would work, maybe roughen up the surface with fine grit paperso it has something to bond on, if your realy stuck it could be a last resort.good luck
Sep 29, 2010 | Boating
I have vertical cracks at the location of the seat attachment. why did it split at this point and how can i repair it ? it is a coleman scanoe .
It cracked at the seat bracing starting at the screw holes due to expansion and contraction of the plastic polyethylene. The heating and cooling effect is caused by storing it outside or worse directly in the sun. Go to www.bullseyetradingpost.com they have a simple fix for this, you should be back in the water in short order,then store it out of the sun.
Nov 27, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Canoe has damage on the front bow.
Bondo would probably work.
Also, you could laminate a few pieces of something like vinyl siding/facia board over the hole. If the canoe is ABS, the vinyl siding cold be "welded" / fused to the ABS with PVC primer & solvent/cement.
May 27, 2009 | Coleman Cable Coleman Inflatable Boat...
Scanoe, Ram-X, Split in hull near gunwhales- Repair, How?
I found a Scanoe like this on craigslist that was being given away because of several splits ins the hull. I was ready to buy that patch kit on line when I stumbled on a solution that worked great! I was in Home Depot looking in their pond department and saw some self adhesive patches for poly ponds. I bought on for less than $7.00 and gave it a try. I sanded the inside of the hull around the split. cleaned it well and applied the patch. It worked like a charm!
Oct 20, 2008 | Coleman Sport & Outdoor - Others
Washing Machines Logo
346 people viewed this question
Top Washing Machines Experts
