JVC VCR Model HR-V605 It keeps rejecting the tape straight away after loading. I've tried different tapes, same problem. Any suggestions? Thanks, Barry.
  • 979 Answers
Load completion switch is not making, usually for mechanical reasons, but could be bad switch...accordianman
Posted on Mar 15, 2008
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
My jvc lcd shutt down every time and i dont know the rason
I can honestly say I have been quite happy with it and its performed pretty well with very few problems and is still going today.
First of all congratulations on getting so many years of heavy use (2002 - 2012) on your JVC VCR.
I have a HR-S3911U and a HR-S5912U from the same era and my 3911 has seen a million miles and both my units are still going strong. I did experience a similar problem with my HR-S3911U but instead of the eject function my problem was with a sticking guide-pin. I did a have similar ejection problem with one of my 1985 Super Beta Hi Fi machines. Really it sounds like the exact problem as you describe. What I did was I opened up the unit and watched carefully - it was just a sticking moving part. My JVC guide-pin problem was just sticking as well - after a gentle push into place the guide pin has not stuck since. I don't suggest using any grease unless you really have to. I suggest you open the unit - if you have a video camera video tape the ejecting and play back in slow mo to see if you can catch the problem. Sounds like a sticking moving part which can be common on any VCR.
..couple times its had issues with dirty heads as i would get a message appear on screen.
I'm very surprised that in the past you had "dirty heads" messages pop up on screen as I have never seen that message on my JVC machines and I do use them a lot and very rarely clean the heads. Proper tape storage is very important. Trying not to use the same tape over and over again also helps keeping the tape path reasonably clean.
I think it could benefit from the heads being cleaned. I don't even really know what are the heads. Is it that big round drum? One thing I did notice is that when I load a tape, it straight away wraps the tape around that drum and the drum spins away and just idles there constantly rubbing on the tape before i have even pressed play. I have left tapes in there for days and days, so I assume this cant be good having that thing spinning away on the tape for such a long time?. I am not sure if this is normal or not but I wont be leaving tapes inserted in the VCR long periods now.
The heads are tiny little things inside the big round drum. I will show you if you post a picture of your unit with the cover off.
The tape staying wrapped around the drum with the drum spinning is normal but the drum should stop spinning five minutes after you load the tape as long as you don't touch play, rec ,ff or rewind. This is called a "long pause" (the tention is a little eased and is not rubbing hard as a normal pause would) and the long pause is there so the unit will immediately start playing or recording if you push play or rec within 5 minutes of loading the tape. If the drum does not stop after 5 minutes of sitting idle then your VCR has a malfunction and you should not leave tapes in the machine idling.
I am concerned about your heads clogging up - that is not normal unless you don't take proper care of your tapes - is there very high humidity in your area? That could cause problems.
Sorry I posted this in a hurry but will go into more detail later if need be.
Porsche Parts.
May 27, 2012 | JVC 32 Class 1080p 60hz Lcd Hdtv - Black...
My JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
my JVC HR-DVS3u Mini DV recorder deck keep displaying use cleaning tape, I use the jvc cleaning tape and it still ask for it.
Dec 24, 2009 | JVC HR-DVS3 Mini DV/S-VHS VCR
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
Tape won't load
The childlock feature might be active try holding the power button on the remote till the vcr turns on. when the VCR turns on try putting a tape in and see what happens I happen to own this very model and has been in service since july 98 and has over 10k hours on it and still works like the day i bought it
I had that same issue a few years ago
Jul 09, 2008 | JVC HR-S3500 S-VHS VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
JVC HR A62U VCR
I was wondering if you tryed unplugging vcr for an hour then
plugging it back up. sometimes this resits it and it will work fine.
the tape might eject itself out or eject button might work.
Nov 10, 2007 | JVC HR-A32 VHS VCR
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
JVC HR-S9700 TAPE STUCKS, HAVE TO BE PULLED OUT, CASSETTE DOOR REMAIND OPEN,VCR SWITCHES OFF-CAN NOT BE PLAYED AGAIN
Check out the drive that works the unloading and loading operation of your machine. Also check the switch that is activated by the presence of your cassette. If something is wrong with the latter, the tape will not load and unload properly. And under those circumstances your machine will not work.
Try Google search for your questions. You may get lucky and get the answers right there!
Mar 13, 2017 | JVC HR-S9600 S-VHS VCR
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
