Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer dryer combo " Washer drum leans to one side "
And thumps when in use mainly spinning
When I pull the drum in the correct position it goes back to the side when I let go.
any ideas on repair?
  • fungames Mar 04, 2008
    I removed the panels from my kenmore 11098573120
    I found 2 of the 3 supports or shocks had busted thru their top mount. The top of the shocks are nickle sized and my mounting holes are quarter sized and as my luck goes both are in the rear. If I can get them pulled back thru I may try some larger washers?
    Thank you
    Problem Solver:
  • 6 Answers
If this is a small combo the problem is probably one or more of the suspension springs has become detached. You need to get the washer cabinet off. take the panel between the washer and dryer off. then there are 2 clamps holding the washer top on. they are in rear right and left. Once you get the top off you will be able to take the front of the washer off. At that point you should be able to see the problem under the tub. In most cases you can reinstall the plastic shaft back into the spring by screwing them back in.. This is not easy but can be done.
Posted on Mar 03, 2008
How do I disable dryer on a Kenmore washer/dryer combo model number 417.99160110 only washer works
You have to start by removing the top first then remove he front console which allows you access to the dryer drum etc
Feb 04, 2016 | Kenmore Washing Machines
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
I need to replace the dryer belt from a Kenmore washer dryer comb
Remove the top lid, then the front panel to access the drum and belt. Unplug the dryer first.
Jun 07, 2009 | Kenmore Dryers
Kenmore washer/dryer combo (Model# 41792702200)
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer/Dryer Combo purchased in late 2000
Call a local repair tech. I know one in Milwaukee :)
Seriously, your machine needs some possibly expensive repairs beyond a novice's skills. The dryer has a felt bearing around the front of the drum that is probably worn out. Check on the rear bearing and the belt at the same time. The washer may need a new transmission, belt, tub seal, and spin bearing. That's an involved repair. Expect to pay extra for labor, but the total bill should be less than the $800 - $1400 for a new machine.
Mar 12, 2008 | Kenmore 24032\24036 Top Load Washer
Thumping and banging
washing machine making noise, remove water but doesn't spin
Jan 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
146 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
