I have bought new Speakers and subwoofer set for my PC ( iball tarang 2.1).... sound is ok, treble knob and volume is working fine. Suddenly Bass sound gone off it wrked for 5-6 secs whn i was testing.. I chked again still the same.. and it gets heat up at the back of subwoofer
    Master:
  • 691 Answers
You may have burned out the transformer for the subwoofer.
Posted on Dec 07, 2017
3 Suggested Answers
mana666
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
yes
Posted on Dec 04, 2007
toesnose
  • 21 Answers
SOURCE: Subwoofer not working
Yea I would say most likely a loose wire going to the bass control, is it accessable to behind the controller easily? if so take a look. they are usually soldered, but it may have been a weak solder point that came loose.
Posted on Jul 16, 2009
I bought a Behringer Eurolive B1220 Pro speaker with my PA system brand new and it sounded great at first. Now it sounds really muddy (the other 2 speakers I bought work fine) almost as if the horn has...
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Nov 05, 2010 | Behringer B1520 Pro Eurolive 15" 2-Way...
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Why does my Boss dvd/cd player sound like somebody huffed heleium
this sounds like you have the treble turned right up.
if you still have you manual refer to that to turn the treble down.
if not due to treble settings and its under warrenty. get a new one.
May 18, 2010 | Car Audio & Video
When playing on high volume the treble dissapear. I have a 2.6kw Cerwin amp. And Clsc 215 speakers. No bi- wire on my speakers. When I lower the volume the treble returnes. What is wrong???
Sounds like your overpowering the horns and the circuit breaker is tripping to prevent them from blowing. You are running more power then they can handle. You can turn down the volume or will have to purchase higher wattage horns...
Mar 24, 2010 | Cerwin Vega Cerwin-Vega CLSC-215 3-Way...
JBL Creature Speakers have very low volume
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Only one computer speaker recieving a signal
Most probably there is a problem in the cable or plug.
Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
Acer ast180 speakers do not work properly the sound is echoing
check the volume , bass, treble settings. Check whether u have plugged the wires correctly
Mar 08, 2008 | Acer Aspire™ T180 PC Desktop
Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Aug 10, 2007 | Alpine CDM-7861 CD Player
Harman Kardon Elegant 2.1 speakers problem
'Sounds' like you have overwhelmed the cone and split it or a solder joint has come adrift Don't know about repair or replacement -Check makers website.
May 13, 2007 | Harman Kardon HK695 Computer Speakers
Chances are you have wrecked the cone and movement with the overly high input. Nor repairable if this is the case. Check out the makers website for more tech info
35 people viewed this question
 Grubhead
Grubhead
