Question about Nintendo DS Console
Won't power up
I want to buy a nintendo ds from ebay. the lady says she switched shells and now it won't power up. she says it flashes quickly then back off is this fixable?
  • melissa78 Mar 11, 2008
    I have a nintendo ds when you press the power button a red light comes on and the screen flashes and it shuts back off. Tried charging it even when to game store and had them test the charge that wasn't the problem. Put in new battery and still won't power on. Wonder if this needs to be recalled?
If when the charger is plugged in the light only flashes on and then straight back off again its something in the mother board. I was told this by a nintendo ds repairer. If the light stays on while the charger is connected its probably a loose connector or a broken screen.
Good luck
Posted on Mar 28, 2008
    Problem Solver:
  • 8 Answers
If she switched the shell, it was probably because the hinge was broken. If this is the case, there is a ribbon cable that runs through that hinge. If it is damaged, the system will blink on and then right back off. You can also see that possibly, only the bottom screen will blink on and off. This ribbon cable will need replaced. It normally runs about $10 total shipped.
Posted on Mar 24, 2008
  • 52 Answers
There is something not properly plugged into the logic board. try opening the ds and make sure all connections are secure
Posted on Mar 17, 2008
Brought a ds lite and new ds shell as the old one had broken hinge.Whilst re routing the black antenna cable broke (gold connection bit came off) i have ordered a new one from ebay.So as this is just for...
If you yourself have replace it, I think you damage the upper LCD ribbon connector. I have repaired a lot of DS, a broken hinge usually the cause of that problem( ribbon connector cut off ).
Check the upper LCD if that model have a seperate ribbon connector, luckily you could buy the ribbon only, if not, BAD LUCK, you have to buy a new upper LCD.
Hope that helps you out.
Thanks for asking FixYa!
Aug 08, 2011 | Nintendo DS Lite Console
Power led lights green, touch screen flashes white and powers off
try taking it apart again and checking closely to see if any inner cable is loose,
Apr 13, 2010 | Nintendo DS Lite Console
Nintendo top pulled off hinges
Look on ebay for replacement shells for DS.
There around $15 and you also need to buy a Special Nintendo Screwdriver
Dec 07, 2009 | Nintendo DS Lite Console
The best palce to buy new shells for the DS Lite
I have seen loads on ebay from all range of colours, your best bet is to find a company on ebay selling them that way you will get the shell through the post in a matter of days usually 2 - 3 working days sometimes less.
Nov 07, 2008 | Nintendo DS Lite Console
Nintendo ds lite not turning on
see if you need new carger or if it needs new batteries
Jun 26, 2008 | Nintendo DS Lite Console
Nintendo ds shell replacement
you may have something that is touchign the screen, or the wiring may have been disconnected accidentally. try taking it apart and putting it back together again.
Jun 02, 2008 | Nintendo DS Console
Heyya
Please specify what the problem is so when you next put something on say what console and the problem, i cant seem to locate you from before, sorry for the inconvenience
Apr 09, 2008 | Nintendo DS Console
Nintendo ds lite
The switch is broken. This is a common problem if the shell case has been removed or if someone simply pushed way too ******* the power button. A new button can be purchased on ebay for under $10. Some soldering and desoldering will be required. The DS Lite is breakable when taking it apart so be careful. You can also send it to a guy like me for a fee and have it fixed or sell the broken unit to someone like me that fixes them.
Mar 29, 2008 | Nintendo DS Lite Console
Nintendo ds broken hinge
you need a new shell, I buy them off of this website www.dealextreme.com
for about 15-25.00 us
Jan 12, 2008 | Nintendo DS Lite Console
Ds not lite
Replace the connector cord between two screens. You can buy new ones from DX Deal extreme! Carefully remove through hinge and attach securely.
Be careful not to break the fine wires connecting. Have to twist the connector cord in the correct way to make it go through hinge without damaging.
Good luck cos it is a fiddly job.
Aug 23, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
