Question about Sony KP-57WS500 57" Rear Projection Television
Trying to get true Split screen with TWC
I have Time Warner Cable in Raleigh-Duham, NC and if I wire the cable for split screen using scrambled cable according to the manual, the split screens do not act independently. Any ideas?
ctf1800
  • 4402 Answers
SOURCE: No signal on main tuner
can you connect comcast to another tv that should tell you if it's the tv tuner or cable company.
Posted on Jan 31, 2008
SOURCE: split /dual screen
You may have inadvertantly pressed this feature on remote. Look for "split screen" on remote or menu, then correct
Posted on Apr 22, 2008
welcomejee
  • 10594 Answers
SOURCE: main screen showing "no signal"
KP-43HT20 has 2 tuners, one is main (TU2) and 2nd is called sub tuner (TU1). Both tuners are mounted on A board located on right side of TV.
In my opinion, main tuner (TU2) is not working and causing No Signal message.
Let me know if you want to repair tv by yourself.to provide you more technical info.
Posted on Feb 21, 2009
  • 126 Answers
SOURCE: Bottom of screen gets cut off.
you need to press the aspect ratio button to change the view is should bring up the news ticker into view if you have your view set to smart try pressing up on the d-pad in the middle of the remote
Posted on Aug 06, 2009
  • 71 Answers
SOURCE: I just hooked up a Time Warner Cable 4250HD Box
You need to make sure that the settings on your TV for the DVI connection are set properly. It sounds as if it is set to stretch or zoom. The reason the HD channels look great is that they dont zoom because the resolution fills up the entire screen without stretching.
I know you want to use your HDMI cables, but since you are going HDMI to DVI you are removing the benefit of the single cable since you still have to use audio cables. You are not going to get any appreciable difference between the setup yo uare using and the component (red, green, blue) cable.
If I have helped you, please rate me as such. It allows me to help others. Thank you.
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Free username and password TWC wifi
How do I log in?
Initial access to TWC WiFi requires the user provide log in credentials that identify the user as a current, qualified TWC Residential or Business Class customer. Credentials can either be a TWC ID and Password or Time Warner Cable email and password.
  1. First, make sure you are within range of a TWC WiFi Hotspot and that the WiFi feature on your mobile device is turned on.
  2. Select TWCWiFi from available wireless networks.
  3. Open your browser. The TWC WiFi Connection page will appear.
  4. If you're a Standard Internet customer or above, enter your credentials. You can either use your TWC ID or your Time Warner Cable email and password.
  5. If you're not a Standard Internet customer or above, request a 30-minute free trial or purchase a TWC Access Pass for as little as $2.95/hour.
  6. Accept the Terms of Use, click Submit and connect.
Jun 22, 2013 | Computers & Internet
TVGOS (TV Guide on Screen) stopped working on Time Warner.
split your input cable line and connect one end to your digital input and the other to your
analog or air input.
Jun 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
According to Time Warner cable I no longer have TV Guide On Screen because the PBS piggy back signal is no longer being sent. Apparently, PBS is getting ready for HDTV. I live in Wilmington NC and we went...
PBS in my area says that my cable provider, Time Warner is no longer using the analog signal that contains TV Guide On Screen info. They did this to prepare for digital in Feb. Time Warner says they are waiting for Gemstar/Macrovision to provide a method for the On Screen feature to work. My source at PBS reckons there are over 25,000 cable card TV's that may lose this On Screen Guide. Apparently there is no legal requirement for TV Guide or your cable provider to send the guide.
Users may want to try and contact TV-Guide/Gemstar/Macrovision directly at their toll free number
1-800-386-7380. This may not be a solution but it may be a consolation for users wanting to know why they have lost their TV Guide On -Screen.
Dec 04, 2008 | Televison & Video
No sound time warner cable
Time Warner Cable just sucks!!!
Feb 02, 2008 | Computers & Internet
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
HDMI connectivity
what does the error message say?
Dec 01, 2007 | Televison & Video
Sony KP-57WS500 57" Rear Projection Television Logo
630 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
