Question about HTC Touch P3450 Smartphone
Htc touch charging port stop working
The charger on my HTC touch phone just stop working for no reason. Help.
  • Anonymous Mar 29, 2014
    phone charges and charger light works but when power button is pushed it vibrates once.. but nothing else happens
    Problem Solver:
  • 17 Answers
It may be caused by dirt ingress in the port, check for dust and clean out with a soft fine paintbrush (like an artist brush) soaked in pure alchohol, or vodka! Short of that solution, purchase a charger of ebay and place battery in the rear to charge.-
http://cgi.ebay.co.uk/DESKTOP-CRADLE-CHARGER-for-HTC-TOUCH_W0QQitemZ130204421069QQcmdZViewItem?hash=item130204421069&_trksid=p3286.c81.m63.l1177#ebayphotohosting
Kind Regards, ACD
Posted on Mar 14, 2008
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Wont charge. i plugged into so many usb cables and box chargers and light wont turn on nothing charges it
Your charging port is probably bad. It is a common issue. You can take it into an electronics shop and they could fix it by sending it to the manufacturer, but it might cost more than a new phone like the HTC incredible
Mar 01, 2011 | HTC G1
I bought a new htc touch diamond phone and within eight months the charger has stopped working. m not able to charge my cell through that charger.please give me d solution as i m not able to use d phone...
First of all your charger is under warranty, so you should get it replaced. Also you may use the USB data cable to charge this phone from your PC. Connect your phone to the computer/laptop using USB cable and it should charge as normal.
May 05, 2010 | HTC Touch Diamond Smartphone
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
My htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Sep 25, 2009 | HTC Touch Pro Smartphone
Helppppppppppppp
well u pronobley need a new battery
Nov 05, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc 8125
there will be some problem in the charger or in the charging port of your cell ..
just have a check with the charger first with another mobile if needed replace it ..
if you still persist the same problem then there may be some problem in the charging port of your cell ..
the charging port may be is in loose contact ie it might not be touching the motherboard of your cell correctly just have a check by opening the cell if you are good at opening if needed replace the charging port ...
rate my solution
Sep 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Phone won't charge
No you cannot use a motorola charger to charge an htc touch.
Aug 22, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
1,028 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
