Question about Cell Phones
Antenna broke and I replaced it
The antenna on my VX8100 broke, so I put a new one on. I'm still not getting a strong signal, though. Other than screwing in the new one, what should I do with the antenna?
  • Mindy007 Mar 20, 2008
    I dropped my samsung Sgh-a707 and now I get no signal. The front screen is broke but everything else is working - but useless because of now signal. Help.
  • 86 Answers
Posted on Mar 03, 2008
    Problem Solver:
  • 14 Answers
If your not sure what to do at this point you probably should stop right here, however if your bold enough to try this, remove the back cover, I believe there are 6 (six) screws in total, there is also a small metal contact that touches the main circuit board on the back side, that also connects to the antenna, most often a springy piece of gold plated metal attached to a solid threaded nut, where the antenna is attached that fits snugly into the back cover of the phone when the cover is installed the nut is secured and won't fall out. This contact could be on the nut or on the main board if you bent it out a bit to make better contact, you will most likely fix your phone. Cheers!
My signal strength is really bad on my TVs. Should I buy a new antenna?
The more tvs you have hooked up to the same antenna, the lower the signal strength. Therefore you should get an antenna amplifier or get a new antenna with a stronger signal.
Jan 31, 2013 | Electronics - Others
Sirius truck antenna stopped working
The truck antennas can go bad. It could be the cable though. You can replace either part at
May 20, 2012 | Sirius Satellite Radio Receiver
Can not get any digital channels
Digital TVs do require a fairly strong signal in order to operate properly. The fact that your set is displaying the "weak or no signal" message is proof that the incoming signal is below the required signal input level threshold.
A "rabbit ears" type of antenna would only work if you were right next to the broadcast transmitter. I assume that you have the rabbit ears fully extended and that you have tried slowly rotating it from one side to the other to see if you can get a signal lock. But seriously I doubt it.
You should check into either a set-top amplified antenna, or a larger roof or attic mounted antenna. Note: While the larger antenna should provide a much stronger (better) signal, they tend to be directional. You might have to put it on a rotator so that you can "steer" (aim) the antenna toward a particular signal. For most people, this is unrealistic due to the expense and complexity.
My recommendation is to get an amplified omni-directional set-top antenna designed to receive DTV signals
Jun 10, 2011 | Philips 52PFL3603D 52 in. HDTV LCD TV
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
May 12, 2011 | Televison & Video
Without connecting the aeriel to the labgear i get 77 tv channels and some music channels but when i put it through the labgear i only get 21 tv channels why am i losing my signal i have put a annuater in...
An attenuator reduces all signals. Attenuators are often used when you are close to a transmitter that causes interference to other stations. By knocking the signals down, the strong signal is less likely to interfere with the other stations, while the other station's signals will be reduced too - many can now be tuned and viewed. This comes with the risk that some stations that had a signal that was just over the threshold of being tuned and watched no longer have a signal level that passes through the attenuator. This is what is happening in your situation.
Determine if you can watch stations you like without the attenuator. If so, do not reinstall it. If you find that some of the stations are being interfered with by another station - see if you can change the amount of attenuation in the device. Some attenuators are adjustable and make this easy to do. If yours is not adjustable, you might consider purchasing an adjustable type - as the one you have is not suitable.
Lastly, consider installing a rotatable antenna. This will allow you to aim the antenna directly at the broadcaster's antenna - allowing you to reject signals not in the same direction. This should reduce your interference from other strong signals that originate from a different direction. This will also increase the signal strength from all transmitters as you can point your antenna directly as the antenna - instead of capturing signals from the side or back of your antenna.
I hope this helps and good luck! please rate my reply. thank you.
Apr 06, 2011 | Televison & Video
My antenna broke off when I went through a car wash, how do I replace it?
if part is still left where antenna was take a pair of pliers and turn counterclockwise(left) to remove old piece left. go to most auto parts stores and they should have an original equipment replacement antenna
Jan 14, 2011 | 2004 Mercury Sable
I accidentally broke the antenna. How can I order just the new antenna to fit in it's place. How much would that be for RCD200 boom box? Thanks,
You would be better off sticking a thick copper wire where the antenna used to be. It wont look very pretty, but you will get a strong signal.
Oct 04, 2010 | RCA RCD-200 Radio/CD Boombox
The antenna inputon back of television broke off,
It is possible to fix it by de-soldering RF Tuner Block from signal board of your TV and installing new one. This repair need soldering skills.
Mar 10, 2010 | RCA HD52W59 HDTV Projection Television
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. will tell you which is UHF and VHF ..
Dec 28, 2009 | Televison & Video
Cell Phones Logo
120 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
