Question about Samsung SC-D353 Mini DV Digital Camcorder
Tape want come out
I have a samsung digitial cam recorder and the tape has got hung up in it the eject door want open anyway i can get this out without tearing up the cam?
How to eject tape
Posted on May 18, 2008
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
Tape door won't open
your cam's eject mechanism drive motor may be struck or damaged, please open the cam and replace it.
Apr 06, 2016 | Video Cameras
Pinch roller stuck in "up" position, eject button won't open door
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Dec 03, 2012 | Audio Players & Recorders
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
Camera won't record a D comes on screen and eject tape comes up.
I have a cam corder model VP-D361 PAL, since i brought i could not use it even a single time, for the past 2 yrs it was kept as it was brought in packed condition, i was using other cam corder of jvc, when i opened and start using it, i found a triangle and a D on the screen, several attepts made by taking out battery, and casset. but still same thing appears,(AFTER REFERING TO USERS MANUAL) it may be a simple problem, or a defective one, since brought a single minute is also not used, kindly help me to solve this problem from a local serviceing centre.at mumbai, india.
My address as below,
K.J.SEBASTIAN
BLDG NO. 7, FLAT NO. 29
BORLA CO OP HSG SOC
DR.C.G.ROAD
CHEMBUR, MUMBAI- 400074
TEL NO. 91-22-2520 5842
MNO: 9892004970,9987904458
Jan 18, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Entire camera is locked up
THIS IS A PROBLEM WITH SAMSUNG SCD 353 LET ME NO IF U NEED MORE REPAIRS
Oct 21, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Samsung SC-D353 Mini DV Digital Camcorder Logo
210 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
