Question about Food Mixers
Free standing hobart 30 quart
First gaer goes very slowly with a slight judder and stops as soon as anything is in bowl not enough power
2nd and 3rd are perfect
Hi ther,i had the same trouble as yours only going in 1 gear the problem was the gearing it self when the nut comes unatatched the gearing system slips from different kogs,needs to be put in shop am afraid,hope this helps you,john
Posted on Oct 07, 2008
    Sergeant:
    Champion:
  • 310 Answers
First gaer is slow one don't add too much.
Posted on Mar 03, 2008
What is the difference between a H800 and L800 mixer
I have used the H600. Nice piece of kitchen kit for hard use.
Model H600 is a heavy-duty 60-quart mixer which features a two-horsepower motor, a timer and a #12
Attachment Hub as standard equipment. With the use of bowl adapters and special agitators, 30- or 40-
quart bowls may be used on the H600.
Model L800 is a medium-duty 80-quart mixer designed primarily for use in general kitchen applications.
This mixer features a timer and #12 Attachment Hub as standard equipment and is powered by a
two-horsepower motor. With the use of bowl adapters and special agitators, 30-, 40- or 60- quart bowls
may be used on the L800.
A Bowl Guard is standard equipment on all H600 and L800 models.
A programmable timer controller is optional on H600 and L800 models.
These mixers can be ordered with a stainless steel finish.
A variety of attachments and accessories are available for all mixers. These are described in a separate Use and Applications Handbook, which is furnished with each mixer.
Here is your manual.
http://www.cvrsupply.com/manuals/hobart/Hobart_L800_Manual.pdf
May 07, 2016 | Food Mixers
Locks up in 3rd gear after rebuild
Jeff your almost there....it must be the shifter into third....it must not slide fully into third....check for wear marks on the worm gear....and try running it without the protective cover on to see how it changes from 1st, into 2nd, then third...that mechanisim if not engaging totally in third.
Dec 03, 2013 | Hobart A200 Stand Mixer
Where can i buy a splash guard for hobart A200
There are two different splash guards fort he A200.
If you have a 12 quart bowl the splash guard is a part number 438078 and if you have the 20 quart bowl the part number is 438079.
Both parts are available from
http://storefront.whaleyfoodservice.com/.
Jun 21, 2012 | Hobart A200 Stand Mixer
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
How can i tell the which size my mixer is?
A 200 means 20 quart. I assume you have no bowl or else you can just measure the volume of the bowl.
Nov 29, 2009 | Hobart A200 Stand Mixer
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Jul 23, 2009 | Hobart D300 Stand Mixer
Trying to locate a wire whisk for my Hobart D-340
Bill. Whisks are not interchangable for different bowls. Try ebay to locate one.
If this solution has assisted you, please rate it. ricardok45
Mar 20, 2009 | Hobart D340-6009 Mixer
New bowl & hook hobart d300
There is a website called onesharpstore.com, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Feb 25, 2009 | Hobart D300 Stand Mixer
Hobart mixer 30 quart
this is an extremly difficult mixer to take apart if you are not tech minded do not attempt this
Nov 29, 2008 | Hobart A200 Stand Mixer
A200 problem
Check the planetary.this is the bottom part of the mixer where you attach the hook.
You will see two nuts; make sure their tight as the planetary may have moved down.
Also have a look below:
http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
Feb 04, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
63 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
