Question about Cuisinart GG2 Indoor Grill
Cuisinart indoor grill "CONTROL w/ CORD"
CONTROL DEVICE PROBLE: The chrome basial on top becomes disconnected from inside, allowing spring to lift thumb turn knob to lift upward, this disengages internal connect. This results in not being able to adjust the heat.
Apparently the basial has two prongs holding this assembly together. They are twisted on the bottom side and are very short, one of them releases, allowing assembly to push up & cease functioning
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: what is the difference between cuisinart indoor grille gr8 and cuisinart indoor grille gr4
Look it up on the cusinart web site
Posted on Dec 03, 2011
How do I remove the Main PCB from an LG ArtCool C12AWR or disconnect air sensor of indoor unit ?
Disassembly - Indoor Unit
Disconnect the unit from power supply before making any checks.
Be sure the power switch is set to "OFF".
To remove the Grille from the Chassis.
• Set the up-and-down air discharge louver to open
position (horizontally) by finger pressure.
• Remove the securing screws.
• To remove the Grille, pull the lower left and right
side of the grille toward you (slightly tilted) and lift it
straight upward.
1. Before removing the control box, be sure to
take out the wire screwed at the other end.
2. To remove the Control Box.
• Remove securing screws.
• Pull the control box out from the chassis
carefully.
3. To remove the Discharge Grille.
• Unhook the discharge grille and pull the
discharge grille out from the chassis carefully.
4. To remove the Evaporator.
• Remove 3 screws securing the evaporator(at the
left 2EA in the Eva Holder, at the right 1EA).
• When repair, do not damage the Caution label.
• Unhook the tab on the right inside of the chassis
at the same time, slightly pull the evaporator
toward you until the tab is clear of the slot.
5. To remove the Motor Cover
• Remove 2 securing screw.
• Pull the motor cover out from the chassis
carefully.
6. To remove the Cross-Flow Fan
• Loosen the screw securing the cross-flow fan to
the fan motor (do not remove).
• Lift up the right side of the cross-flow fan and the
fan motor, separate the fan motor from the
cross-flow fan.
Sep 07, 2015 | LG Art Cool LA121HNP Split System Air...
I have a brand new cuisinart gr-4n grill with a broken hinge, purchased at auction. Is there anywhere to buy replacement parts?
Try visiting http://www.cuisinart.com, you can check there the nearest authorized parts dealer in your area.
Feb 26, 2011 | Cuisinart GR-4N Indoor Grill
Looking for a GG-2-PR for a Cusinart GG-2
everyone knows Cuisinart products save time and now they save space, as well. The Cuisinart™ Grill & Griddle has a large reversible, nonstick plate to make it two appliances in one. An embedded heating element lets you evenly grill poultry, meats, fish and vegetables. Not in the mood to grill? Flip the cooking plate and set the electric thermostat to perfectly cook pancakes, eggs, crab cakes or fajitas!
Feb 21, 2011 | Cuisinart GG2 Indoor Grill
Where can I purchase the Cuisinart GG-2PR Probe with Control Knob - i ordered it from Cuisinart - they said they had it - but it came backordered cancelled! Thanks...Dennis
I don't know where you live but I have had to replace two of these now and I go to Servicetek in Mississauga, Ontario 905-602-5191. I understand that this grill has been discontinued which is no surprise to me because the probe in particular is garbage. We originally paid about $135.00 Cdn. for this item and I have had to replace the probe twice at $35.00 plus tax per time. Once this one goes, I will replace it with a better quality item. Hope this helps.
Oct 18, 2010 | Cuisinart GG2 Indoor Grill
Won't heat up
Thermostat control.
The only heat-producing piece on this model is the probe itself.
I'd say give the manufacturer (Cuisinart) a call. If you're under warranty, they can probably replace the probe for free. If you're out of warranty, you can purchas a probe (so either way, you're covered :))
Their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Aug 28, 2009 | Cuisinart GG2 Indoor Grill
Maverick indoor grill 20 series
good day,
hope this link below will solve your problem.
grilling
Oct 19, 2008 | Maverick D2870 Indoor Grill
Cuisinart GG2 Indoor Grill Logo
53 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
