Go to
http://www.bbbind.com/free_tsb.html free wiring diagrams ! You having tail light problems ? Do you know how they work ?
They are turned on by the BCM !
Park, Tail, Marker and License Lamps
The park, tail, license, and marker lamps are turned ON when the headlamp switch is placed in either the HEAD or PARK lamp positions, or anytime the automatic light control (ALC) turns the headlamps ON. When the headlamp switch is placed in the park lamp or headlamp positions, ground from G202 is applied through the signal circuit to the BCM indicating the park lamp request. In response to this signal, the BCM applies ground through the park lamp relay control circuit energizing the PARK LP PCB Relay. With the relay energized, battery voltage is applied through the switch side of the relay, both park lamp fuses, and the supply voltage circuits illuminating the park, tail marker, and license lamps. Ground for the left front park and marker lamps is provided at G101 and the right front park and marker lamps at G100. Ground for all rear lamps is provided at G302.
Turn Signal Lamps
The LT T/SIG and RT T/SIG fuses located in the underhood fuse block supplies battery positive voltage to the body control module (BCM) for turn signal and hazard lamp operation. When the turn signal switch is place in either the LEFT or RIGHT position, ground from G202 is applied through the turn signal switch signal circuit to the BCM indicating the turn signal request. In response to this signal, the BCM applies a pulsating voltage to the front and rear turn signal lamps supply voltage circuits cycling the lamps ON and OFF. The BCM also sends a message via GMLAN to the instrument panel cluster (IPC) to cycle the turn signal indicator ON and OFF depending on the position of the turn signal switch.
Ground for the turn signal lamps is supplied as follows:
G101 provides ground for the left front turn signal lamp
G100 provides ground for the right front turn signal lamp
G302 provides ground for the left and right rear turn signal lamps
Thanx
I have had it checked by the an agent.
There was a short in the circuit somewhere.
Luckly I didnt have to have the switch changed or it would have been expensive.
