Question about IBM Lexmark Z715 InkJet Printer
Can't connect to computer
My computer finds the printer. I can go into it's properties but I cannot get it to print. Light is blinking on face of printer. Is it out of ink? I just got it from a friend but I can't even feed paper through. Please help
Todd
  • Anonymous May 30, 2008
    Printer works on my 4 yr old EMachine and a neighbor's computer. Both have XP. My new Acer desktop has Vista. It's all hooked up and have checked all cords to and from between printer and computer. When I click on the computer screen print button, nothing prints and the computer screen says, "no connection with printer." Checked control panel's add printer/installed printers and it's the only one we have listed. I'm trying to print a page from Word.
  • Anonymous Sep 22, 2008
    I cant conect to my computer
    Problem Solver:
There is a anti virus software that comes with the Vista (I hate Viatsa) and it is blocking the communication of the printer to the computer. I had to have Geek Squad come and they were the only ones that could figure that out. They removed the anti virus software and then it worked fine. I hope that helps you. I am sure at this point you either figured it out or bought a new printer.
Posted on Jan 10, 2009
HP Deskjet D1460 - Does not print. Continuous blinking power light when turned on, with or without being connected to a computer. Under normal circumstances, shouldn't the printer power up &...
the obvious fault is a lack of communication between the computer and the printer from not having the correct driver installed
using microsoft drivers can lead to problems so it is best if you go on the HP web site , select the driver download for you model and install the driver direct
you can also right clivk on the printer and then click on properties tab , click on compatibility tab then click in the box and high light the win os you are using to rectify compatibility problems
Oct 21, 2017 | HP DeskJet D1460 InkJet Printer
When the printer has big green light and a orange light what does this mean?
Do you mean that the orange attention light is lit and the Go button/light is lit? If the attention light is blinking, then the printer is in manual feed mode or out of memory.
Put in the media and press the Go button. To reset the media selection, go to the Printer Properties. When printing from an application, click Print and then Properties. From the Printer control panel (Start > Devices and Printers (on recent Windows versions) or Start > Settings > Printers (on older OS versions - prior to XP).) In either case right click on the printer icon and choose Properties or Printing Properties.
If you have too large a file (too many large images) and are out of memory, stop and cancel this file in the print spooler. Then reprint with a lower resolution. (This is in the Print Quality options. See the above and then the Paper/Quality or Finishing tab) Options will vary depend on the OS. Alternatively, add memory to the printer.
If the Ready light is also lit, the error depends on the pattern. If the lights are blinking in rotation, then the printer is initializing or printing a test page. If the lights are steady, you have a fatal error. Try unplugging the printer for at least 5 minutes (remove all cords from both the wall, computer and printer for the best chance of clearing the error.) If the error persists, the printer needs service. If all of the lights are blinking together, than you have an accessory problem. Try removing the memory. You may be able to reseat the sticks; alternatively replace the memory.
I hope this helps.
Sep 03, 2010 | HP LaserJet 1300 Printer
Hp 3475 light goes on blinking, does not print
Hi
Either of the two problems make the printer blinks-.
check them out.
1. If you have given the printouts and all the pages are not printed then if there are pending printouts remaing in the printer properties the printer will blink continuosly.
2. Any of the 1 cartridge out of 2 may be faulty.
and last option if the printer cover is not closed properly it blinks.
Jul 23, 2010 | HP DeskJet 3745 Printer
It doesn't print. The message doesn't seem to go
open the printer lid and check that the cartridges start moving towards the left side and they will stop in one of the "sad faces" then replace the bad cartridge corresponding to that "FACE"
Mar 09, 2010 | HP DeskJet 940c InkJet Printer
I just changed my ink cartridges. The test page will print, but the computer page I'm trying to print...won't. In the bottem righthand corner the printer icon keeps blinking along with a left facing...
hi,
First of all would like to help you so that you can cancel your print job.
On the bottom righthand corner where the prinetr icon blinks simply right-click it and select "cancel," after which the print job status commences to display "deleting..."
So you shoud not be worried about loosing your receipt as you can print it again.
Also
  1. I would like you to unplug the USB wire connected from your computer, turning the device off and then connecting everything from scratch. You can also restart the computer.
  2. Then once the computer is on please click on START and go to RUN and type in services.msc and then on the right side of the page find print spool and right click, then choose restart.
And then try for fresh prints.
Please let me know if the above information helps.
Feb 09, 2010 | Office Equipment & Supplies
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
The printer will not print.
I did what Andy told me to do and the printer started working. However, what I realy wanted to know was if the problem was in the printer or in the computer and I did find that out so that I will soon buy a new Printer.
Jul 06, 2009 | Canon BJC S450 InkJet Printer
Flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
Cause
The printer has difficulty picking up label media. Solution
  2. Press the power button once. Wait a moment for the paper jam to clear.
Cause
There is a paper jam. Solution
Cause
There is a problem with a print cartridge. Solution
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Mar 03, 2009 | HP DeskJet 3520 InkJet Printer
Blinking light
The blinking light indicates a failure of the print job which can occur for a couple of reasons.
1. empty ink cartridge. Ig you take it to a local walgreens they will perform a test for you free of charge.
2. Go to control panel, then printers, then click on the printer you have installed. check for print jobs pending and delete all of them,
4. Right click on the same icon and go to properties, there you will find a maintanence area look for a troubleshooting area and follow the procedures.Let me know how it turns out..Be mucho blessed..Mark
Jun 11, 2008 | Canon BubbleJet i320 Printer
Our Canon Selphy DS810 is not printing any color on the photo paper. I cleaned it several weeks ago, we have a new ink cartridge in and nothing. It was printing a light yellow color several weeks ago...
There are all kinds of printers and printing problems. It’s important to note at the outset that for safety reasons you should unplug your printer if you plan on working inside the device for any reason. In addition to the electrical hazard, printers (especially laser printers) can also be very hot on the inside, so use caution.
There are a few general troubleshooting steps you should take first, regardless of your printing problem. These will help solve most everyday printing issues.
Reboot. You’ll be amazed at how many printing problems simply disappear after you restart your computer. Also, reboot your printer. Sometimes, for no good reason, a printer will become wedged (it just stops communicating with the computer). Turning your printer off for a few seconds, and then back on, will usually get you going again.
Read the printer’s lights. Doing this can provide you with very useful clues. Is the power light on? Is the paper feed light blinking? Don’t be afraid to press buttons on the printer: Turn it off and on, reset the paper feed, and take the printer offline and bring it online again.
Check your physical connections. Is the power cord loose? Does the cable from the printer to the PC have a secure connection at both ends? Look at the connector pins on your cable. Are they bent? Try another cable if you have one. Check the print cartridges and printing mechanism. Is anything blocking the printer? Are the cartridges firmly in place?
Print a Windows test page. Access your printer’s Properties dialog box (follow the directions given above). Select the General tab and click the Print Test Page button. If nothing else, you can find out a good deal about your printer’s problem. If the test page prints, you have a problem with your application, not with Windows. Answer the questions as prompted and work through Windows’ Print Troubleshooter as needed.
Drivers. Verify drivers on the Details tab in the Printer Properties dialog box. Make sure the installed driver corresponds with your actual printer. Check the manufacturer’s Web site for updated drivers and browse the support pages on the site while you’re there.
Mar 06, 2008 | Computers & Internet
IBM Lexmark Z715 InkJet Printer Logo
101 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
