Question about Sony KP-46WT510 46" Rear Projection HDTV
8 blinks My Sony KP46WT510 just shut off no picture no sound and the standby light is blinking 8 times. I've tried to reset by unplugging for a short time then plugging back in with no change. What could this be? The repair place Sony recommended as their authorized repair facility wants $150.00 just to come look at it.
  • 1 more comment
  • efdjake Mar 03, 2008
    Thank you! Do you think it is expensive to fix??
  • Anonymous Mar 27, 2008
    i also have the 8 led flashes. i have sound but no picture for about 4 to 5 seconds then the timer/standbt light starts the 8 flashes again.
  • Anonymous Sep 26, 2008
    i have the same problem, the tv just shut off and when you power up you get sound for a few seconds then nothing.??
    8 led flashes on front panel.
I need some info on the boards
Posted on Aug 18, 2012
  • Sony Master
  • 8,617 Answers
8 blinks on your model number means High Voltage error. Which means TD8005 is faulty on the D board.If you need any additional info please let me know
Posted on Mar 03, 2008
  • Sonny Berry
    Sonny Berry Mar 03, 2008
    Excuse the typo thats T8005 on the D board.
  • Sonny Berry
    Sonny Berry Mar 04, 2008
    You would be looking at about 30.00 for the part and if you can solder you should be able to do the repair yourself. Let me know if you need any additional info.
Sony bravia shuts off
A short circuit with its main board component, can make 8 blinks of standby/power light. These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 28, 2014 | Televison & Video
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Standby light continuously flashes with no picture or sound
count the number of blinks; you may have to unplug the set and try to turn on again--if it does not blink in a sequence(3 blinks, a pause etc) the set is in shutdown and many things can cause this.
Aug 06, 2009 | Sony KP-53HS10 TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Sony kp-51ws510 tv blinking light 6 flashes on timer/standby
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Model kdp65ws550
High voltage protection. Either transistor Q8014 04 Q 8013 is shorted along with R8051 on the D board or IC 8005 is defective on the D board. Let me know if you need more assistance
Apr 22, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
103 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
