Question about Cameras
Memory error When I try to delete all the items from the camera I get the message CARD ERROR and when I'm flicking through the photos taken and get to the end of it it says READ ERROR.
How do u format a card
Posted on Aug 13, 2008
  • 121 Answers
-you will have to go to the settings and format the card hope this helps
Posted on Mar 03, 2008
I Have taken pictures with the camera , after it saves it keeps telling me photo error , im trying to recovery images i have taken , and they are unable to view and when i copy them to my pc , windows says...
Your pictures may be corrupted.You can recover those corrupted pictures with this
1. Do not save any new pictures into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
How to Recover Deleted Pictures from Digital Camera's Memory Card?
Aug 22, 2011 | Vivitar ViviCam 5385 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
All photos were deleted on Kodak Easy Share M381 (sandisk) in error - can they be recovered?
Yes, they can be recovered if you take care. Also if you want to maximize chances of Kodak camera files recovery, the first thing you should do is immediately stop taking more photos or videos (with your current digital camera) in case partial files are overwritten.
Then connect the camera (memory card) to a PC or Mac which has install a data recovery tool, check this site Digital Camera Photo Recovery for a list of good and tested recovery software.
Hope you good luck! Merry Christmas! Regards
May 18, 2010 | Cameras
I have a Fuji FinePix Z20 and I deleted all my
do a web search for free file recovery software and follow instructions to the letter.
Aug 04, 2009 | Cameras
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
Apr 29, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Picture error and loss of pictures taken
In this case you should use recovery software to see if you lost pictures can be got back. Recommend you have a try of Wondershare Photo Recovery, a program which can recover lost pictures, videos can music with both Windows and Mac version, you can free download the program from the sites,
(For Windows Users)
http://www.wondershare.com/pro/photo-recovery.html
(For Mac OS Users)
http://www.wondershare.com/pro/mac-photo-recovery.html
Step-to-Step Instruction:
1. Download and install the trial version on your computer, then connect your camera memory card to the computer (I assume you are using Windows). Start Wondershare Photo Recovery and select the drive letter that assigned to camera memory card.
2. Then choose the file type (all, photo, video, music) click "Star Scan".
3. Now the scanning process will start automatically to look for the deleted items. You will then get a list of all recoverable ones.
4. Preview the photos. If your deleted ones are found, then you need pay to get the activation code. And click "Recover".
Tips:
1. Take the free trial version before you buy.
2. Before your deleted items are recovered, do not save more files to the card.
I hope you good luck, Merry Christmas!
Jan 03, 2008 | Cameras
Lost all the pictures on my camera Panasonic Lumix DMC-FZ7
A lot of Photo Rescue programs are available to recover your media card.
Mar 05, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Message Display
sometimes this problem occures due to defective or fake memory media. try using a good branded card.
Sep 09, 2006 | Panasonic Lumix DMC-FZ10 Digital Camera
Cameras Logo
107 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
