Question about Epson LX-300+ II Matrix Printer
FX-300+II 284.4 @EJL code
Hi!
I have a FX-300+II printer, used with XP driver ( ESC/P version) and RS232 link.
On every printed documents the printer print this message code :
284.4
@EJL
You have a solution for eliminate printing of this code?
good work!
Marco
5 Suggested Answers
SOURCE: Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Posted on Nov 10, 2007
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
SOURCE: PRINTING TWO EXTRA LINE ON
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Posted on Oct 21, 2010
SOURCE: Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Posted on Feb 24, 2011
Epson FX-890 prints 284.4 @EJL, what could be the problem
I already did answer a question like this today. Just google this, because this error is on the net, for many different computers and different OS'n. look what suits the best.
Jul 16, 2014 | Epson FX 890 Matrix Printer
Epson fx- 890 prints 284.4 @EJL what could be the problem
I googled this, and lots and lots of other users had the same problem. There are different solutions, depending on what computer the printer was connected.
Please google yourself, to see what solution fits the best.
My epson lq-300 printer prints @EJL 1284.4 @EJL at the top first why
@Nelstin: You are wonderful, perfect. I followed his instructions, deleting "@EJL 1284.4" and "@EJL" in two *. GPD files, the LQ-300 prints out normally. Thank you very much.
Sep 22, 2012 | Epson LQ 300+ Matrix Printer
Everytime I print there is un usual text that eppear in the upper left corner of my print out paper.. The error shows like this; @EJL 1284.4 @EJL
When a printer prints garbage, it usually indicates a faulty cable or a loose connection. Power OFF your printer and computer. Disconnect and reconnect the cable on the printer and computer. Once the cable has been reconnected, power the printer and computer back ON.
If you are still getting the error, take the cable and printer to another computer and it works fine, have your computer's port checked. If it still gives you garbage from another computer, have the printer taken in to be serviced.
Apr 05, 2011 | Epson LX-300 Matrix Printer
Epson Status Monitor 3 : Epson LX-300+II ESC/P 'Communication Error' appears after printing successfully ?
Jan 28, 2011 | Epson LX-300+ II Matrix Printer
Good day! i just want to ask, do i still need installer in installing LX-300+II in any computer?
Hi, it depends on which operating system you are using. By deault some operating system got the Driver. otherwise you need to install the driver for the printer. for driver download follow the link http://download.cnet.com/EPSON-LX-300-II-ESC-P/3000-2116_4-106032.html.
Thank You,
Dec 13, 2010 | Epson LX-300+ II Matrix Printer
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ570+ RUNNING ON WINDOW 7
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
Sep 01, 2010 | Epson LQ 580 Matrix Printer
Print output
I had the same problem when printing on Windows XP Pro or Vista Business OS while the prinout was fine using DOS or Linux environment. My problem was that every other line the fonts wiggle sidewards towards the right as if it were on italics.
To correct this, simply download the LX300-II ESC/P driver then update your printer driver by re-installing it using your device manager.
Apr 16, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II Matrix Printer Logo
1,875 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
