Question about AEG 24 in. Favorit 40310 Free-standing Dishwasher
AEG Favorit 446 Dishwasher gets stuck on final rinse
Hi, my old faithful AEG has recently developed a problem. It washes OK, but the dial sticks on the final rinse, and it seems like no water is coming in to perform the rinse. There is also a high pitched whine - sounds like a motor or pump. If left like it, the machine gets hotter and there is a burning smell. There is no water in the bottom, so it is draining OK. I suspect that no water comes in for the pre-wash rinse and hold either.
I have checked the water supply and inlet filter, they are OK, because the machine goes through the wash cycle. The dishes are clean, but have salty soap residue.
Any advice gratefully received.
mastermaid
  • 502 Answers
SOURCE: AEG FAVORIT 443 Manual I need a manual. How to
Hi, I found the Favorit 443 manual here
Posted on Aug 19, 2011
  • 35 Answers
SOURCE: My AEG 60820 dishwasher is continually having
Buy a new one. Whirlpool, Kenmore,or MayTag
Posted on Jan 07, 2010
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 20 Answers
SOURCE: I need an manual in english for the AEG Favorit
try here. http://www.serviceforce.co.uk/pdf_search.asp
Posted on Jan 21, 2010
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorit 6040 Dishwasher has continuous tone (from Pump?) even when switched off at the power button. It cannot be set to any programme.It overflowed some froth when put on a recent cleaning 'phantom...
This sounds like the anti flood system has triggered. This does put the washer on a pump out mode and the outlet pump runs all the time. The trigger device is a polystireene slab in plastic bracket with miro switch at the bottom of the washer. Dry the bottom out and check for water leaks (hose clamp / hose) and this should solve the problem.
Nov 11, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Dishwasher keeps cutting out
Has the door got heavier recently?
Mine had a spring break which fell onto the electrics and shorted them. Unplug and empty it, then tip it up to see if you can see a loose spring. If it is then replace or re-fit the old spring, I have posted instructions and pictures here:
http://www.howtofixanything.co.uk/howto-260.html
Jan 24, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Feb 20, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
AEG 24 in. Favorit 40310 Free-standing Dishwasher Logo
100 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
