Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the
freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal
Alert error, the Reset on-screen button almost never responds to a
tap...I invariably have to depress the reset button in the back of my E2.
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419)
resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887)
Depending
on a variety of factors including the available memory on your E2 and
other installed applications, the problem might or night not be caused
directly by the program you were trying out. But once you get the E2
unfrozen, you should refer to this article to troubleshoot the cause of
this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
Also,
I recommend going to the developer of the software you are using, to
determine whether there are any compatibility issues at their end, and
whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
We have a Mobile VB application. The PDA is mounted on a PP55 printer. I suspect the Dataviz is causing some problems. In addition, the Backup Pro might be another thing. We can use it to backup but cannot restore.
Does this only happen when running this Mobile VB app?
