Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Where do I buy parts for gateway fpd1960
.I plug it in no power to anything not even light to the power button,
I SUSPECT the power supply circuitry went bad? thx
  • dave Mar 03, 2008
    dont know much about electronics ,I could only soldered.
  • 2,336 Answers
I'm sorry to say that in today's electronics devices, there is not much support anymore when It comes to service parts.
In many cases the same boards have to be fixed if you want that device to be functional again.
Posted on Mar 03, 2008
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
I have a FPD1960 monitor that will not turn on. I
The most common problem with the FPD1960 is a failure of the power supply board pictures here.
The capacitors overheat and bulge causing them to fail. If you can solder then you can do the repair yourself. Here is a link to a parts kit: http://www.ccl-la.com/catalog/product_info.php?cPath=21_30&products_id=206
I hope this helps, if so please rate my solution.
BuddyMc
Apr 17, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
I have a gateway that is plugged in but continuously reboots
bailerie, Gateway and most all other LCD displays DON'T know how to reboot! They have NO need to do that! You must tell me what you see when you RECONNECT FPD1960 to a already fully booted, KNOWN GOOD pc that is currently displaying the WIN-desktop! Then and only then power-up the 1960 unit and observe what is going on and for how long! The only guess I can make about this problem is this. The "switch-mode-power-supply" inside your monitor is cycling IN and OUT of SHUTDOWN MODE because it has detected a FAULT of some kind with another circuit or even with itself. Get back to us so we can further help you. 12fixlouie Bye for now.
Nov 07, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor problem. Monitor was working fine, I left it on and the next day it was off the the even the green light was off.
Same prob here..except mine occured next use--outlet has power--cables are secure-just NO light on button--i'm thinking power supply button or board--I have found these parts on e-bay for 15.00--will let U know if it works
Jan 19, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 TFT LCD Color Computer Monitor suddenly went dead
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 05, 2017 | Dynex 19 in. LCD Flat-Panel HDTV
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
19 "lcd gateway monitor will not power on.
Have you tried your monitor on somebody else computer?
Jun 14, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
186 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
