1996 Ford Taurus Logo
Posted on Mar 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Alternator removal/ford taurus 1996 - 1996 Ford Taurus
  • Anonymous May 11, 2010
    This depends on the motor your car has. If you could let me know if it is a OHV V6 or the OHC V6 i can help you out. The OHV V^ is a little easier to do its located in the front and you can access it from the top but the OHC V6 it is the easiest to get to it from behind the right wheel well and underneath. This one is a little more time consuming and a little harder and you also need to have your car jacked up and and sturdy jack stands to work safely just keep that in mind.
Wayne Fellows
Level 2:
  • Ford Expert 262 Answers
  • Posted on Mar 14, 2010
Wayne Fellows
Ford Expert
Level 2:
Answers
262
Questions
Helped
246089
Points
802
Generator Removal
  1. Disconnect the battery ground cable.
  2. Remove the accessory drive belt from the generator pulley.
  3. Remove the power steering line bracket and heater hose support bracket from the generator.
  4. Remove the upper generator bolts.
  5. Partially raise the vehicle on a hoist.
  6. Remove the right front wheel.
  7. Remove the lower fender splash shield retainers and position the shield out of the way.
  8. Remove the generator splash shield.
  9. Raise the vehicle.
  10. Disconnect the electrical connector and remove the battery positive cable from the generator.
  11. Position an adjustable stand to the subframe.
  12. Remove the right subframe bolts.
  13. Remove the lower generator bolt.
  14. Lower the subframe to provide clearance.
  15. Remove the generator
Generator — 3.0L (2V) and 3.0L (2V) FF Engines
  1. NOTE: The generator (GEN) (10300) is not internally serviceable.
    Disconnect battery ground cable (14301). Refer to .
  1. Disconnect the electrical connectors from the integral generator/voltage regulator.
  1. Loosen the generator pivot bolt. Remove the mounting brace bolt from the generator.
  1. Disengage the accessory drive belt (8620) from the generator pulley (10344).
  1. Remove generator brace.
  1. Remove the generator pivot bolt and generator/voltage regulator.
alternator removal/ford taurus 1996 - 524109a.gif
2answers
1996 Ford Taurus GL 3.0 - V6. Is there a diagram of the distribution fuse box for it please?
copy and paste
https://fuse-box.info/ford/ford-taurus-1996-1999-fuses-and-relay
Where is the regulator on a 1996 ford Taurus 3.0 v6 can someone answer it for me i need some help?
Regulator for what ? If you mean the voltage regulator it is mounted on the back of the alternator.
My 1996 Ford Taurus has a positive cable ground fault. Where does it terminate and How do I remove the positive cable from both ends to replace?
Most cars have the positive cable routed to either the starter, starter relay or the alternator... just follow the cable backwards from the battery. Should be obvious how to remove it once you take a look (guessing an 8mm wrench for the battery end and a 13mm wrench for the other end).
How to chg alternator on 2002 ford taurus 24v dohc 3.0
ctionsThings You'll Need
  • Flywheel holding tool
  • New alternator
  • Socket wrench set
  • Torque wrench
    • 1Determine which alternator your Ford Taurus will need. You'll want to be sure the new alternator is compatible with your Taurus's engine. Models made from 1986 to 1991 have a 2.5 L HSC, 3.0 L Vulcan or 3.8 L engine. The 2.5 L engine was dropped for 1992 to 1995 models, and post-1995 models will have a 3.0 L engine.
    • 2Disconnect the negative battery cable with a socket wrench. Release the tension on the accessory drive belt so that you can remove the drive belt from the pulley.
    • 3Take off the mounting bolt on the right side of the alternator with a socket wrench and remove the bracket for the power steering hose. Remove the mounting bolts on top of the alternator, the front passenger wheel and tire assembly and the front fender splash shield. Remove the alternator splash shield with a socket wrench and take off the inspection cover for the torque converter.
    • 4Mount a tool to hold the flywheel so you can remove the crankshaft pulley bolt and crankshaft pulley. Lower the alternator so you can unplug its electrical connections. Disconnect the crankshaft position sensor and Oxygen sensor connector. Remove the lower alternator mounting bolt and B+ connector nut to remove the alternator.
    • 5Install the new alternator assembly by reversing the above procedure. Use a torque wrench to tighten the B+ connector nut to 71 in. lbs. and the lower alternator bolt to 18 foot pounds. Torque the crankshaft pulley bolt to 74. foot pounds, the upper alternator bolts to 18 foot pounds and the nut for the power steering hose bracket to 13 foot pounds.
Read more: How to Replace the Alternator in a Ford Taurus ' eHow.com http://www.ehow.com/how_4506222_replace-alternator-ford-taurus.html#ixzz1ZdgFklse
2answers
How to remove an alternator from for taurus 1996
disconnect neg. battery cable.disconnect alternator electrical plug. note routing of drive belt,see decal on radiator brace or take a picture.remove drive belt
remove 2 bracket to alternator bolts on OHV models,2 bolts & 1 stud bolt on OHC.
reassemble in reverse order.
1996 Ford Taurus GL 2000 3.0L 4V Battery Issues?
you need to get a adapter from any auto store that can handl e load you want
1helpful
2answers
1996 ford taurus odometer stopped working
the Speedo in your car is electronic, the problem is the tiny motor that moves the needle is most likely defective, there are no parts for the Speedo available to the consumer from Ford, you must remove the Speedo and have it repaired by a authorized Speedo repair shop. here is a link to a good one I know about.
http://dnaspeedometers.com/
1996 Taurus Wagon - Intermittant electrical drain while running
I would have the alternator and the battery tested for proper operation, Kragen auto and other chain auto part stores do this for free.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
