Unplug turn off your printer. unplug its power cable lift the printer up put it in an upside down position shake the printer from left to right for 2 mins.
This troubleshooting will help you find out if there's any foreign object stuck inside the printer.
after that put the printer back to its position, turn it on then try a test print.
If you can also locate the rollers at the back of the printer, try to clean it as well.
It sounds like a bit of paper is stuck somewhere in the paper feed route. Remove the toner cartridge and any other bits that pull out. Removable bits often have a green tag or finger grips moulded in to them. Do a careful check in the printer for any bits of paper or even a full sheet stuck somewhere. Carefully remove all rubbish and reassemble.
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Try this. Remove any paper jams, take out all sheets of paper and remove all cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. The printer will print an alignment page. Load just 5 sheets of paper only. Let it print the alignment page all the way through without cancelling it. If printer is not making the squealing noise, problem resolved. If it's still making the noise, the printer's mechanism somehow got affected by the paper jam now. If that's the case, any mechanical/hardware problem in the printer, it's better to ask assistance from Lexmark. If printer is damaged already, and it's still within warranty, they might send you one for replacement. Good luck!
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
If its not taking the paper, it may be that the paper you are using is not the right type. Some papers are too smooth or shiny to allow the guide wheels and platten ( roller) to grip the paper. This oftemn results in no paper or only one side of the paper being caught and then it jams.
Wipe the platten with alcohol, as welol as thye guide wheels if you can see them. Ink tends to stick on them and the platten and becomes shiny ans so paper will slip. Also try a heavier grade paper to see if that rectifies the problem
The printer will attempt to pull in a sheet of paper out of the tray. If none is pulled, this is noted because a microswitch is not closed by the paper sheet as it goes by. This is the cause of the message. Check to be sure that the rubber roller that grips the paper initially is clean. I'll leave further comments to Benimur our local printer expert.
You need to clean your pick up roller or replace it. I use rubber restorer you can use 91% isopropyl alcohol and a q-tip. Please clean quickly. Don't use anything below this % or you can damage your roller.This should do the job. Let me know if this works.
the paper feeder cant grip the back side of the paper. It slip through the feeder and the positioning led control cant adjust the correct positioning for printing!
