Re: I cannot sync music from ituneson windows vista to
I think the Iphone your using is already linked to another itunes library, so once you link to the current computers itunes library the song there after wont be deleted.
This way should fix the issue about sync music from iPhone 5 to PC without iTunes: - After your iPhone 5 connected to PC, launch the program you will see the right UI. - Choose the list and music files you want to transfer , Click the "Export" button. - After you clicking the "Export" button, the following window will pop up, you can choose transferring to computer or iTunes directly. You can set the output folder at Advanced->Options before transferring. - When the transferring finished, the following window will pop up. Done!
Syncing music and podcasts automatically Connect iPod or iPhone to your computer and open iTunes. Select your iPod or iPhone in the Devices section on the left side of the iTunes window.
In the main iTunes browser window, select the Music tab. Select the option to Sync Music.
THEN CLICK APPLY IN THE BOTTOM RIGHT CORNER AND YOU DONE!
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
Connect your iPhone to iTunes and do the
following:
1.On the summary tab of your iTunes sync
settings check "Sync only checked songs and videos"
2.In your music library check all the
songs you want to sync to your iPhone
3.Make sure there are no exclamation
points next to any of the songs you want to sync to your iPhone
4.Make sure you have authorized your
computer for all Apple IDs for purchased music you want to sync to your iPhone
(in Store>Authorize This Computer)
5.Check "Sync Music" on the
Music tab of your iTunes sync settings
6.Sync your iPhone If above can't help you, the below article may give you a guide. Transfer music from my iTunes library to iPhone Good Luck!
How to Reformat iPod
In order to reformat iPod to work on both Mac and PC, connect your iPod to a Windows computer. Then follow the steps in the how to restore your iPod article. This will reset your iPod and format it for Windows.
Now, resync your iPod with the computer that contains your iTunes library. ITunes will ask you if you want to erase and sync the iPod. If you say yes, this will redownload your iTunes library to the iPod.
At this point, you may also need a way to easily move your iTunes library to the second computer. A quick way to do this is with software that copies the contents of your iPod to a computer. Learn more about iPod copy and backup software here.
Checking iPod Format
Each time you sync your iPod, you can check what format it is. In the iPod management screen in iTunes, there’s some data at the top of the window next to the image of your iPod. One of those items is “Format,” which tells you how your iPod is formatted.
Suggested Reading
1. Open iTunes. Open the Edit menu on Windows or the iTunes menu on a Mac. Click the "Preferences" option. Make sure the "Disable automatic syncing for all iPhones" check box is selected. 2. Plug your iPhone into the computer and wait for iTunes to recognize it. Click on your iPhone's icon on the right side of the iTunes window. Click the "Music" tab. 3. Select the music you want to sync to your iPhone using playlists. You can also select the option to sync all your music to the iPhone. 4.Click "Sync" when you're done customizing your settings. Get more details: Transfer music files from Mac to iPhone
Zone Alarm and itunes do not play well together. ZA running will corrupt some pictures, apparently some music and does not allow the update of an ipod (touch) to occur. I have had to turn off ZA for any of the above to get either a clean install or adding (or removing) photos.
iPods connect to your computer via iTunes. You can download iTunes here free: http://www.apple.com/itunes/download/ All the music files currently in your Windows Media Player can all be transferred into iTunes, so no worries about losing your music.
you cannot log on itunes through the unlocked phone itself,to download music.instead,you must download itunes to your mac or windows vista pc and sync phone through pc to download music. if you update iphone with itunes through the phone it will auto update firmware on the phone ,and your iphone will work no more. h A ck T & T USER
