Engine runs good but after running about 10-15 minutes just dies. Cranks but won't start after 10-15 minutes starts back up and goes for a while, acts like no fuel changed fuel filter.
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
To clarify - - if the engine cranks the battery and starter are ok. The alternator does not come into play until the engine is running. If it cranks but won't start, you have to figure out if you are missing fuel to the injectors or spark to the plugs to proceed. A mechanic would check that and if there are any trouble codes stored in the computer.
You mean that the starter is turning (cranks) the engine but the engine won't start? Be sure it is getting fuel. Turn the key to the on position and you should hear the fuel pump in the fuel tank run for a few seconds. If so that is good. If the fuel is being delivered then possibly you have no spark which usually is the electronic ignition module. The only way to test it is to replace it. Your timing chain or belt could be broken or "jumped" as the third possibility. I am leaning toward ignition module being bad as they just die without warning and nothing can revive them.
CHECK ALL THE IGNITION ELECTRICAL WIRES ON THE IGNITION SYSTEM.CHECK MAKE SURE FUSES ARE IN TIGHT.IF YOU BATTERY IS OLD.I SEEN A BAD BATTERY KILL THE ENGINE.IT HAS A PLATE SHORTING ON INSIDE.IT WILL KILL THE ENGINE.LIKE YOU TURN OFF YOUR SELF.
