Question about Samsung SCX 4521F All-In-One Laser Printer
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
  • 17 Answers
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Posted on Feb 28, 2010
    New Friend:
1 problem in my printer when i copied or scanned any picture or document it give output black line or black ground of paper. what is it solution ?
Posted on Sep 19, 2010
SOURCE:
What would cause tray 1 to misfeed every 12 to 15 sheets? The misfed sheet ends up laying on the edge of the paper tray advanced about 3/8" from the paper stack?
check your paper thickness setting in your drivers
2. clean separation pad at the bottom of the paper tray
3. clean rollers located after the pick up area(registration rollers)
4. check actuators for the sensors to see if they are sticking
Jul 29, 2014 | OKI C9500dxn Led Printer
Hp officejet 1280 is picking too many papers once and it jams
The intake to the paper could have an alignment issue as it is possible that two or more sheets get into the slot.
so check if the printing paper is of the correct grade and is not lower than the recommended thickness.
A paper of low thickness can cramp into the slot and jam.
Also if the paper has a tendency of sticking this can happen , check if there is moisture on the sheets.
Finally clean the intake section, the inner rollers and the pick up roller. the alignment of the rollers are to be checked.
Jul 29, 2011 | Computers & Internet
My printer pulls multiple sheets at once.
yo have to:
1. Clear paper pick up roller whit wet cloth or alcohol
2. Clear separation pad (located under pick up roller) using same way as pick up roller.
Good luck
Jun 18, 2010 | Samsung ML 2010 Laser Printer
Printer error as stated "Printer Mispick [Enter] to resume." There was a mispick but that was corrected; however the error message is constant.
Hi:
I own a HP Laserjet 3330, and usually all that it takes to fix this problem is cleaning off the paper pick up roller with a damp cloth.
It is having trouble picking up the paper sheets, and you will get the error time after time. It seems that the recycled paper is worse than others. Remember to use a cloth dampened with only water, as other cleaners will dry out the pick up roller
Oct 26, 2009 | HP LaserJet 3330 All-In-One Printer
My printer does not pick up the paper sheets from the paper tray.When I took paper sheet in to slot it works.
Well - I don't know if this will solve it (since there could be many causes) but it worked for me.
1 - Remove Paper Tray
2 - look at rubber rollers in printer undercarriage
3 - carefully remove "rubber bands" from roller
4 - turn rubber bands inside out and carefully return to rollers
5 - remove toner cartridge
6 - remove print drum assembly
7 - return printer drum assembly and toner cartridge
the roller trick helps the printer pick up paper
the toner/print drum trick helps reseat the inner workings of the printer correcting any misalignments that impede paper flow
Jun 09, 2009 | Lexmark E232 Laser Printer
Doesn't pull paper sheets without foroward push by finger.
for printer not picking the paper
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Apr 03, 2009 | Samsung SCX-4725FN All-In-One Laser...
Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Jan 02, 2009 | Samsung ML 1510 Laser Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Canon ip90 printer wont grab paper
The most likely culprit is that the rollers that pull the paper are dirty. Use the steps below to clean the rollers.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
1) Confirm that the printer is powered on.
2) Remove any paper from the printer.
3) Press and hold the <Resume/Cancel> button.
4) Release the <Resume/Cancel> button after the Power lamp blinks three times.
Note: The Power lamp will blink and the paper feed roller starts cleaning itself by revolving.
5) When the Power lamp lights in green, repeat Steps 3 and 4 up to two additional times. (Please wait approx. 30 seconds for paper feed roller cleaning to complete.)
6) To confirm whether cleaning has been performed properly, set a blank sheet of plain paper (8 1/2 x 11 Letter size) in the sheet feeder or cassette.
7) Press and hold the <Resume/Cancel> button and release it when the Power lamp blinks three times. (The paper set in the printer is picked up and fed.)
8) Repeat the process as necessary
May 12, 2008 | Canon PIXMA iP90 Mobile Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
1,277 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
