No, you fix it by replacing it.
If the noise comes from the axle itself, check the oil level, if it is full, you may tray an oil aditive designed to stop axle noise, they do work.
Also check the axle shaft bearings, they may need lubrication or replacement.
Be careful and good luck
It may quiten down if it is low on fluid if it still makes noise the pinion gear my me broken.
