Looking for comcast remote codes for the LD370SC8 sylvania tv/dvd, any suggesations
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
SOURCE: Comcast remote code
Guys, I checked in my booklet that came with the comcast remote. I could not get any of the codes online to work but the first one in the Comcast booklet did.
The codes listed for the Toshiba LCD TV's are: 10845 and 11656
The first one worked for me...
Remember, on your comcast remote. Press the tv button once, hold setup until the tv button flashes twice then enter the code.
If you enter the code correctly then the TV button will blink twice. If not, repeat the entire process.
If the TV button blinks twice after entering your code the hit the power button. If the tv goes off you know you are good to go!!!
Hope this helps!!!
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
SOURCE: Comcast universal remote control does not have setup code
Try 1864. It worked on my Media-Com remote when none of the other codes worked
SOURCE: comcast remote code for sylvania
I have the same problem. I found that there are many Comcast remotes by the way.
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
