Well, are your batteries in the right slots, and put in right position? Are the batteries used? Was your camera exposed to water? These might be reasons why this is happening to you. If this isn't a very good solution, I have more details, want them? Email me at [email protected] with the subject on the message as: MOREDETAILSFORCAMERA
Thanks,
lbv44
Testimonial: "Thank you for the information, it was very helpful."
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
Testimonial: "Thank you for your help. Extremely useful."
I have olympus fe-190 camera.it is fulle charged and ialways charge it brore use but the camera open's only for few minutes and then closes .i have also bought a new battery for it but the same problem remains. what should i do?
Thank you.
Yes, the battery is in the right slot & position. The battery is the one that came with the camera which I've had for about three to four years. The camera hasn't been used very often & the battery hasn't been removed from the camera between uses apart to recharge the battery on the odd occasions that I wanted to use it. no the camera wasn't exposed to water.
