You can purchase a wide variety of high quality Eureka replacement parts for your Eureka Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
That means that the belt
is starting to wear. When the belt starts to stretch it can't turn the
roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here
is a link to the belt you need and to the manual:
sounds like the pipe is stopped up,, you need to take it off and run a rod through it and unclog it,, sometimes small toys ect. can get in pipe stop ot up,, hope this help you,,good luck
I no more use Eureka 4331 (Boss Lite). But the most common reason for not picking up dirt might be the vacuum bag might be full. Need to be Clean or replace as recommended by the manufacturer or The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner's manual for cleaning instructions. I recommend having Eureka Power Speed for yourself.
Hi
Check the duster wand on this model and make sure that it is clean. Sometimes dust will fall off it if it hasnt been cleaned properly. Even if the hose has been checked there could be an inspection part of the cleaner (where the dirt enters the bagless bin) which hasn't been cleaned out. If this fails, then it could be somewhere else on the machine which is leaking dirt. Check the soleplate - I believe with this model it is front hood which pops off via 2 - 4 philips screw heads made viewable on the front and just below the wand/hose mount release on the left hand side if looking at the vacuum from the front. Check that the main dirt channel at the front isn't clogged. This is one way of dealing with escaping dirt.
