1996 Isuzu Oasis Logo
Posted on Feb 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My daughter was driving my van and lost ALL power. at the same time. all systems went down, and the tranmission gear box locked. any ideas?
Ned White
Level 3:
  • Isuzu Master 2,100 Answers
  • Posted on Mar 01, 2010
Ned  White
Isuzu Master
Level 3:
Answers
2100
Questions
0
Helped
811175
Points
6188
Sounds like the alternator quit. You can get a fresh battery in there and go about 20 miles till it drains, but it won't run without the alternator or the battery. If that is not the problem the Ignitor under the seat is bad, I would try the battery first, it is a lot cheaper than the ignitor. I'm not sure what it is called or where yours might be located, but that is where mine was. But the ignitor wouldn't kill the whole car like the alternator would. I hope this helps.
My wipers...lights..radio and horn went out but I can drive the car..what would cause this?
2008 Chrysler Town & Country Intermittent Electrical Failure ...
www.carcomplaints.com/Chrysler/Town_Country/.../intermittent_electric...
The 2008 Chrysler Town & Country has 25 complaints for intermittent ... The horn,lights, wind shield wipers front and back going crazy could not shut off. .... I was Driving down the road and my van went crazy possessed! ... Electrical checks reveal nothing wrong with the electrical system, and there is power to the radio.
2003 Dodge Caravan ES Electrical Problem - Discussion on Topix
www.topix.com > Dodge Grand Caravan
Aug 7, 2011 - my van was running fine, shut it off, went in for half an hour then it would not ... or the electric doors. windows do and brake lights. heater stays on hot and i can only ... My horn wipers,power windows, radio,blower front and back, headlights, do not work. ... Chrysler Readies Next-Generation Town & Country.Missing: 2004
Thread: I lost almost all of my dash lights, instruments, and ...
forum.chryslerminivan.net/.../7261-I-lost-almost-all-of-my-dash-lights-i...
Jan 17, 2008 - 10 posts - ‎6 authors
I have a 2003 Town and Country mini-van and I lost power to all my ... In addition to this my wipers, headlight controls, blinker controls, power door locks, and A/C/heat controls are out as well. The odd thing is that the power windows work, the power sideview mirrors work, the radio and ceiling lights also work.
I have a automatic transmission and my van will not go into drive or reverse..
Assuming it is a 4L60E trans. The first thing to do is change the filter & replace the fluid. Have the shop check the fluid pressure. Other than that there are numerous things that could cause your problem. Could be the torque convertor on it's way out. P.S.There is no timing belt in a transmission.
Mazda 1990 T3500 CAMPER-VAN reverse gear is ( stubbon ) locked
When a vehicl is in storage for a long time and hasn't been started ,the oil drains off the gears and any part above the oil line will rust and jam up. Try removing the lock unit as the dedent ball in the unit may be rusted in the out position and not moving out of the way to allow gear selection.Don't be surprised if the gear box and diff make some noise when you drive it.
3answers
My vw transporter van has lost its power
something went wrong on the electronics and put your automatic gear box on Safe Mode.Call your mechanic.Do not do anything as a scanner is required for a solution.
6helpful
2answers
My 2000 MPV gets stuck in park. The parking gear will not light up to indicate the van is in park. Once the van is running for about 20 mins or more the parking gear light will come on and I am able to...
it sounds like a shift lock solinoid ....this prevents the car from being shifted out of park when ur foot is not on the brake....u will have to bring this to a repair shop since the faulty part is located inside the paneling where ur shifter handle is
1helpful
1helpful
2003 Kia Sedona lost all power and check engine light went on as I was driving down the freeway - any ideas as to why?
I have the same van, with the same problem. I took it in while the engine light was on and it came back as the crankshaft sensor.
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Isuzu Expert? Answer questions, earn points and help others
