LG WM2277H Front Load Washer Logo
Posted on Feb 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vibration on 1400 spin - LG WM2277H Front Load Washer
Anonymous
Level 3:
President:
  • Master 1,185 Answers
  • Posted on Feb 28, 2010
Anonymous
Master
Level 3:
President:
Answers
1185
Questions
Helped
385883
Points
3708
If it does it with no clothes in then :
Drum Loose, Suspension leg shot
Inner drum out of shape
200 series vibrating around 1400 - 1600 RPM. Any ideas of the problem.
Will it vibrate in park or neutral? or going down the road?
Gas tank vibrates 1400 suzuki 1993
Check the rubber vibrations insulator's at the front of the tank are they still there?.
My 1995 F350 Powerstroke "Shutters"
VIBRATION - DRIVELINE RESONANCE/VIBRATIONBETWEEN 1400 AND 2000 RPM WITH CONVERTER
Clutch ENGAGED DURING MEDIUM TO HEAVY
THROTTLE CONDITIONS - VEHICLES WITH 7.3L DI
TURBO ENGINE AND TRANSMISSION BUILT PRIOR
TO 11/13/95 (5L13)
^ TRANSMISSION - E40D - DRIVELINERESONANCE/VIBRATION BETWEEN 1400 AND 2000
RPM WITH CONVERTER
Clutch ENGAGED
DURING MEDIUM TO HEAVY THROTTLE
CONDITIONS - VEHICLES WITH 7.3L DI TURBO
ENGINE AND TRANSMISSION BUILT PRIOR TO
11/13/95 (5L13)
FORD:
1995-1996 E-350, F-250 CREW CAB, F-350 CREW CAB
Article 96-26-21 is being republished in its entirety as part of a consolidated 7.3L diagnostic aid booklet.
ISSUE
Some vehicles with transmissions built prior to 11/13/95 (5L13) may exhibit a driveline resonance/vibration between 1400 and 2000 RPM with the torque convertor engaged. This may be caused by the torque converter.
ACTION
Prior to torque converter replacement, refer to the following Service Procedure for details to verify conditions.
SERVICE PROCEDURE
1. Verify the resonance/vibration does not occur in neutral and is most noticeable between 1400 and 2000 RPM with the converter clutch engaged during medium to heavy throttle conditions. Also watch for the vibration to diminish at engine speeds lower than 1400 and higher than 2000 RPM. If the concern meets all of these conditions and the transmission has a built date prior to 11/13/95 (5L13), replace the torque converter. Refer to the appropriate Service Manual for removal and installation procedures.
2. If the vibration concerns do not meet the conditions, check for non-factory installed items that could affect driveline and verify proper installation. Also refer to the appropriate Service Manual, Section 05-00 for diagnosis and testing.
107118085
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
2answers
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
1helpful
Vibration
The carbs should be synchronized every 20k miles. If you are having a roughness in idle then I would recommend the carbs being synched. If the problem is at higher RPM's I'd check to see if the motor has a harmonic dampener that can be adjusted. This often resolves vibration issues. I'm just not sure if this bike has one. These big bikes usually have some sort of adjustable dampening device internally.
I'd also like to have you check the motor mounts. This is a common problem if your bike has any rubber in the motor mounts. The rubber wears or even breaks and you often cannot see it until you actually try to remove the mount. Often they will fall apart in your hands.
These big motors all vibrate a bit so many of the manufacturers have realized that adding modified motor mounts is helpful.
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
