I have an LG LCD with TruMotion 200Hz. Few days ago I noticed that when it's turned on the picture/color was not right (all blurry/polarized?). I turned it on and off as I thought might just be bad connection at that time. Apparently it's like that when it's turned on after being off for some time and I noticed it eventually comes right after about few minutes.
Any idea what is happening??
Thanks & Regards,
Michael
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
SOURCE: TruMotion
dont put the LCD neaer magnetic things like speaker or ampilifier......when the problems happend?
SOURCE: LG 1715S faulty
I can confirm the number 3 solution. I have fixed a bunch of these now.
Replace capacitor C202, 680uf 25V. It is usually visibly damaged. It should be a low impedance type, often known as "suitable for switch mode power supply".
SOURCE: Bad smell in our washing machine LG Front Loader WD-8074
You don't have to drain all the water out after each use, you just need to clean things up a bit.
There is a problem with the design, in that the drawer area is a breeding ground for mould.
There will be a latch on the drawer you need to press to remove it - take it out and wash it in a hot solution of borax. Alternatively bleach it, and then wash in hot detergent.
Use a spray cleaner designed to kill mould and mildew, and use it with a brush inside the drawer apature to remove all mould build up. It's quite a grotty job - but needs doing.
After that, use a cloth to clean as far back into the pipe as you can.
Do two washes on hot with bleach, then a rinse, and it's good to go.
It is most important you leave the drawer open after a wash, and the door open more than 2" on these machines to prevent it, and a hot wash occasionally for whites. Tell the manufacturer that you won't be buying their brand again.
SOURCE: TruMotion Demo.
Hi Harry,
From the Picture Menu, the option at the bottom is Trumotion demo.
Highlight this and press enter, turn demo off, press return.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
If anyone else has the same problem it can be sorted by going into the main menu - select display - select advanced at the bottom of this screen - in this menu you can turn on/off the trumotion demo.
