Ok since you have A 625 it uses different technology than the 4000 in a sense but I will assume that whomever connected the 625 use a Dish Pro Plus LNB. You can verify this by going out to the dish and looking at the LNB which is the eyes if you will on the dish. The cover facing you will read DP Plus, or Dish Pro, Dish Network, or you may have nothing at all on the housing. You will want it to say DP Plus for the easiest install.
On this LNB there are three ports. You will only need the two on the left if looking at it so you can not read the housing. One of the ports will be connected to a line running to the 625 and the other to the 4000. The line going to the 4000 should not contain any breaks in it after the ground block if one was used. Once inside the house connect the line from the lnb for the 4000 to the back of the receiver. Conect the receiver to the TV and run a check switch. This receiver will go into a test of 1 of 38 if all connections are good. A 1 of 50 indicates a loss of signal somewher on that side of the install.
The 625 can utilize di plexers but that type of install is to detailed to go into straight away so we will connect it using a straight feed to TV2. Run the cable from the LNB into th room with the 625. Inside connect that line to a siver device called a seperator that came with the receiver and connect the two leads from it to the sat in ports on the back of the receiver. Connect a line to the Home distribution port on the back of the receiver and run it to the room with the second tv you want to have DVR in such as a mater bedroom etc.Connect the cable from the tv out port on the receiver to the tv. Power all devices on and run a check switch. This test should read 1 of 3 if all connections are good. A bad connection will read 1 of 38 on the receiver. A total absence of signal will stay at 1 of 1 for a longt ime brfore going to 1 of 38.
You will need to call dish and activate the 4000 rx since it has not been on the account for some time and will need a software update that they will send to it via satellite.
Other obstacles could arise and if they do let me know. Thanks for using Fix Ya.
