Hi i have lost the instuction booklet and i go into file and i cant delete and reset ie the date, excersize time but it allows me to change the total kcal however is there a quick way of deleting the kcal. Thanks
1. Press and hold the "SET/EL" button until the display changes to "LIGHT
OFF"
2. Press "MODE" until the date section of the display reads "HOUR". Use the "LAP/RESET" button to decrease the value and "ST/STR" to increment the value
3. Press "MODE" to adjust the minute value and then the second value
4. When finished, press "SET/EL" to return to the normal mode
I have the casio 3353. When I read hte manual to do different things, it always startes the instruction by saying "in timekeeping mode". In the instuction booklet at page 8 it shows a picture of the watch face in timekeeping mode and in the picture the face shows the day and date. My face is showing the digital time here. How do I show the day and date,or the timekeeping mode?
You need some thing with quite a small point like a fairly sharp pencil
to depress the buttons fully.
Just pressing the M button will display
the date, to adjust the date and time press the A button, first press
allows you to change the month, second press the date, third press the
hour and fourth press the minute. when you are on the one you want to
change use the M button to scroll through the numbers.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
hold the left, bottom button (marked ....) for a few seconds....then
press the top right button (marked with 1 dot) to change between the
hour, minute, date etc. use the bottom right button to advance the
flashing number, and when finished setting time and date, use the
bottom left button to stop the numbers flashing and return the watch to
normal. hope this helps, this is also how to change the date for the
other question asker (works on 2 other starck/fossil watches i have and
i assume the controls are the same).
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
