Question about Epson Stylus 1400 InkJet Photo Printer
Epson stylus photo 1400 paper feed
My printer keeps repeating paper intake procedure, but does not take the paper. I have tried this with other epson papers and the problem persists. Once in a while for no apparent reason it takes the paper, but this is 1 in 50. It is very frustrating and non productive.
  • 6 more comments
  • mach16lt Mar 09, 2008
    I have the exact same problem, and it is driving me insane
  • frustrated73 Mar 14, 2008
    Yes, same exact problem!
  • cantprint Mar 15, 2008
    yep, same very frustrating problem It either refuses to feed the paper though, or it sends it through but doesn't print.
    Has anyone fround a solution to this problem?
  • guest456 Mar 11, 2009
    I've tried the soft cloth, but my printer keeps jamming the paper. Any suggestions?
  • Anonymous Mar 26, 2009
    Same problem! Really irritating!
  • Anonymous Apr 26, 2009
    THANK YOU THANK YOU THANK YOU! The cleaning solution was a life saver for me. You have no idea how much you saved me tonight. Had a customer order that needed to get out and my printer stopped feeding.
    FYI - I used the wipes from WalMart and then cleaned it back off with a coffee filter. Worked great. THANK YOU again!!!!
  • jay1390 May 03, 2009
    paper is properly seated but printer will not take it in when I send somethig to be printed. the printer is brand new. i have a feeling it's a software issue but i'm not sure.
  • Lenny Hipp
    Lenny Hipp Mar 02, 2014
    epson printers are junk when it comes to paper feeding. mine has NEVER worked properly since the day i bought it
I have the same problems. Very frustrated. Has anyone found a solution to this??
Posted on Mar 15, 2008
  • cantprint Mar 16, 2008
    FOUND THE SOLUTION! I followed the advise I read on another epson thread somewhere. All you need to do is run the printer a few times with no paper. While it's "printing", use a soft cloth (I used a monitor cleaning cloth) and your index finger to clean the rubber wheel that pulls the paper through. The wheel is on the right side in the area where you feed the paper.
    After hours of struggling with this tonight, it is now working perfectly. Guess I'm going to have to invest in a stash of monitor cloths...
    Hope this helps resolve the problem for you.
Here is another alternative!
My girlfriend had the same problem as you and she discovered the best way to fix this problem is:
With a Cue tip and Rubbing Alcohol, clean smoothly the wheel on the right side of the printer.
That will work for sure ;)
Posted on Mar 31, 2009
Thank you so much to all the people who repsond to these types of things. It's 3am and I was about to launch my 1400 out the window. Cleaned the wheel and its taking the paper fine again. Must have been the excess fibres from the somerset textured paper. Thank you printer boffins!!
Posted on May 02, 2010
  • Kenneth Cox
    Kenneth Cox Jun 29, 2016
    Where is the Whell, i don´t find it
I had the same problem, and none of the solutions appeared to work. I finally got out my flashlight, and lo and behold, a small screw had fallen off an adjacent shelf near the printer and was lodged at the bottom of the paper-feeding mechanism, near the pinch clip. Removed the screw (it was definitively NOT from the printer, I know what device it came from) and all has been fine. So, if all else fails, MAKE SURE that no foreign objects have fallen into the paper feed area!
Posted on May 27, 2009
  • Paul Munroe
    Paul Munroe Dec 17, 2016
    DO THIS BEFORE YOU DO ANYTHING DRASTIC lol
SOLUTION! We had exactly the same very frustrating problem. The paper would feed about 1 in 20 goes with nothing printed on it. Finally we realized the back of the paper feeder with the pinch clip on it can be set to a forward or backward position. The solution is to grab the pinch clip (that adjusts the paper width to A4 or A3) and wiggle it until the tray clicks into the forward/up position. The paper should now meet with the rollers correctly and feed through without any trouble. I have no idea what the backward position is for (maybe to feed through a mattress, or just to frustrate the hell out of you on your easter weekend!) The result however is that it is now working perfectly. Chris
Posted on Apr 10, 2009
Usually caused by excess fibre build up on the paper feed roller. Whenever I use an Inkpress paper to make postcards, the paper feed stops after 5-6 sheets. I solve the problem by pressing a piece of adhesive tape on the surface of the feed roller while it is stopped, then pulling it off. Several applications are sometimes required. Occasionall I use a dry toothbrush and brush the roller sideways with the grooves while it is feeding with paper rmoved. The sticky sheets that Epson sells work, but are too expensive to use frequently.
Posted on Sep 01, 2012
Another solution to clearing the paper feed error is instead of just turning off the printer -- unplug it from the wall for about 30 seconds. There is some residual memory that unplugging it will clear. This works on the professional level Epsons so maybe it will work here.
Posted on Aug 19, 2010
I have an EPSON Photo 1400, its only a couple of months old. I had a bad paper jam and now the "out of paper" light is blinking really fast, faster then normal. I pushed the button and the paper feeds trough but I can't it to print or the light to turn off. Also my ink low light is on and when I push it to replace the ink nothing happens. I have turned the printer off and rebooted my computer turned everything back on and still have the same problem.
Posted on Jun 29, 2010
  • jtrop Dec 13, 2010
    Kept getting a "jam" error, when there wasn't any, only when I used vellum paper. I put pieces of tape over the right and left ends of the paper, where it feeds through-- and no problem!
  • jemimacsims
    jemimacsims Dec 16, 2012
    Thankyou! There was a drawing pin inside my printer, but I also gave it a good clean whilst I was looking for it, so thanks for all the tips! Saved me a lot of time and money!
4 Suggested Answers
Inky
  • 691 Answers
SOURCE: Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Posted on Apr 12, 2007
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
Why does my epson 1400 keep loading paper straight threw instead of printing?
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Epson photo 1400 ink & paper lights keep flashing after I print. Then I have to shut printer off and re-start.
I read another epson thread somewhere and it said this:
"All you need to do is run the printer a few times with no paper. While it's "printing", use a soft cloth (I used a monitor cleaning cloth) and your index finger to clean the rubber wheel that pulls the paper through. The wheel is on the right side in the area where you feed the paper.
After hours of struggling with this tonight, it is now working perfectly. Guess I'm going to have to invest in a stash of monitor cloths..."
Hope it helps...
Sep 16, 2011 | Epson Stylus Photo 1400 Printer
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
Jan 30, 2010 | Epson STYLUS R350 Photo Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
The paper just feeds through my Epson 1400 without printing and then the paper/trash can light blinks on.
what? you expect me to give you an answer to my own problem for nothing while you want to charge me $20 for "maybe" some help to resolve my printer issue? You've got to be kidding! What a "chintzy" way to make a buck!
Jun 04, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson 1400 simply pulls blank paper through when I try to print
I've had the same problem. Drives ya nuts. Found that error said dvd/vcr release something or other on the epson print monitor. In any case, I found that if the front door isn't securely closed. (the front door you open to insert the dvd thingie, the paper will just feed or not feed at all. Once the door is closed on the front, the feed works fine again.
Smles,
Writenright@aol.com
Dec 14, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson Stylus  1400 InkJet Photo Printer Logo
8,354 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
