Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp office jet 6110 all in one
When i switch the printer on, it says self test, then it sounds like it is trying to print but then make a sound like it is pulling paper through, then when this is finished, it will say scanner failer, turn of and on again, i have done this several times now, please help
THE Office Jet 6110xi has the problem is the scanner carriage having a problem when it looses power. The carriage does not "see" the signal it needs to indicate to the scanner carriage has reached the end of the scan deck -- I open the scanner top (remove screws, lift ONLY several inches leaving the front "clips" or "clamps" connected so the rear part of the top deck lifts up).
I have wiped the glass and the scanner carriage.
THE BEST THING THAT SEEMS TO WORK IS TO MAKE SURE THE THIN PLASTIC INSERT BETWEEN THE GLASS AND THE PLASTIC DECK --- WHICH IS NOT SEEM FROM THE TOP SCANNING DECK BUT ONLY FROM THE UNDERSIDE WHILE HOLDING UP THE DECK --- IS PROPERLY SEATED SO THE SCANNER CARRIAGE "SEES" IT.
ALSO HAVING WORKED IS SOME COMPRESSED AIR BLOWING IN THE SCANNER CARRIAGE AREA. I PRESUME SO DUST GETS IN THERE AND THE AIR REMOVES IT.
This happens almost every time the scanner/printer looses power, so I usually try to avoid unplugging it or shutting it off!!!
Finally, do not give up. This can be fixed. Sometimes it took 2 minutes, sometimes it took an hour of cleaning, wiping, blowing air into it.....
M
Posted on Mar 09, 2008
Will my hp officejet 6110 work on chromebook
Yes your hp office jet 6110 works on chrome book by following the below methods:
Method 1: Check system requirements
• Chrome book connected to the network with an active Internet connection.
• Create Google account in the latest version of chrome browser.
• The printer hardware is set up and connected Chrome book with a USB cable or wireless network.
USB connection: Make sure the cable is securely connected to the printer and to a working USB port on your Chrome book or computer.
Wireless network connection: On the printer, make sure the wireless signal is turned on and the printer is connected to your network. Make sure the printer is connected to the same network the Chrome book or computer connects to.
Method 2: Install HP Print for Chrome
1. Open the Chrome browser, and then go to the HP Print for Chrome
2. Click ADD TO CHROME.
A confirmation message displays. Adding the HP Print for Chrome app
3. In the Add "HP Print for Chrome" window, click Add app to confirm the new app.
Feb 01, 2017 | HP OfficeJet 6110 All-In-One InkJet...
HP office jet 6110 all-in-one Scanner Failure message cannot be erased. When power is switched off/on makes load grating noise and Scanner Failure message reappears. Copier function will not work either.
Print head sticking needs oil on shaft that its slides on. Open cover and put a drop of oil on each side print head Shaft cut it back on and see if this helps .may half to do this 2 or 3 times to get the oil on to bearings . They dry out over time. Good luck
Aug 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp office jet K80 recieves fax, sounds like it is printing but pages are blank
It sounds like an empty cartridge. check your cartridges, it may be time to replace them. You have to give more information like did you try a print test and if so did it print ok? have you tried to have someone send you a test fax from different numbers?
Jul 17, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I cannot get my HP office jet 6110 to align the cartridge
I was able to find free support online. I recommend others do the same instead of having to pay a fee to fix a simple problem.
Sep 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Blank Pages Printing
Does the printer show up under "Printers and Faxes" on your PC? Click on Start / Printers and Faxes ...to see if it's there? If you see other printers in the "Printers and Faxes" window...is your 6110 listed as the Default printer...that is...is the icon for your printer marked with a small checkmark?? Is there more than one instance of your printer in the "Printers and Faxes" window? If so, you should delete all but one and make sure the remaining one is marked as the default printer.
Jan 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
