Question about Canon BubbleJet i560 InkJet Printer
Printer won't print
The message states the paper thickness lever is the cause.
What and where is the paper thickness lever, and how can I correct it?
Does anybody know about Canon printer problems and error codes?
I have a Canon i250 printer and has flashing yellow light, and 7 beeps.
Thank you
Silviu Hategan
  • sales99 Sep 11, 2008
    I have a canon i250 printer and it won`t print . It registers that it knows what to print but a fault note comes up saying it has full ink in colour and black but that is wrong, i was running low on the black and have now put a new one in but it will still not print . The green light is flashing from green to orange but nothing happens it just says printer is busy. i have turned the printer off and on and still is the same.What could i do next to make it print . thank you.
The lever is right above the ink cartridges. Turn on your printer and open the lid like you would to change the ink. You'll see a small blue lever that has two positions, left for regular paper and right for envelopes.
Posted on Mar 24, 2008
I found help with the beeps and light at http://www.annoyances.org/exec/forum/winme/1175058422
Posted on Mar 14, 2008
I know that the paper lever is where your paper is loaded. Check the grey plastic tab and try to drag it to the right or left. Depending on your paper size you might have to check the owners manual.
Posted on Mar 05, 2008
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Canon i550 yelow light on: "operator error" . Have tried to resume and delete printing tasks and restarted printer
Had the same problem with my I550. Was going to buy a new printer (I4000) since I could get one for about $30 more than the price of a new print head. I like canon printers with the individual ink tanks and have had no problems with the I550 for about three years.
Decided to try moving the paper thickness lever back an forth a number of times since some of the error messages indicated it could not determine the setting of the paper thickness lever. I don't know how the printer determines this switch setting but I thought if some contacts are slightly oxidized that movement might break up some of the oxidation. After operating the lever about a dozen times the printer started working. Hope this will help.
Oct 12, 2009 | Canon BubbleJet i550 InkJet Printer
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
EPSON LX-300+II PRINTER
check the paper thickness lever located at the left side of the printer, set this lever to the lowest possible setting that your paper can handle. This is the darkest that the printer can print. Other than this, it may be an application issue. Check for contrast settings in your program.
Jun 24, 2008 | Office Equipment & Supplies
Paper thickness lever postion
Is there a lever inside the printer that can be moved back and forth? If so set it about half way and try again.
Jan 17, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Printer won't print
hi Printer won't print but the paper come out
Jan 02, 2008 | Canon i 550 InkJet Printer
Failed to print
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
May 26, 2007 | Canon BubbleJet i550 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
800 people viewed this question
old marine
old marine
