if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
you have to stop the blade turning. Grip it with some locking pliers but it might damage the blade. Or jam it with a piece of wood/ stone and undo the nut.
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
There are a couple reasons why the blade is wobbling. Either the diamonds are glazed over because the material you are cutting is way to hard or the blade is very thin and when metal gets hot it expands and when you make a longer rip cut it will tend to wobble. I sell blades for a living and i can almost gurantee this is the reason
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
