Question about ASUS A7V333-X (A7V333-X/L) Motherboard
Asus a7v333 motherboard
I installed a 1gb stick in my motherboard, retarted ans would not boot. Took out added stick and now it goes through booting all cd drives then stops, display will not come on red led keeps running, still has original 1g and 1 256mb memory in it. Was wondering if it fried my orignal memory and thats what it is searching for or if I messed up motherboard? Thanks
  • Timothy Shotwell
    Timothy Shotwell Mar 03, 2008
    dassault1, thanx for your response, I am new to this (woohoo!) but my display wont start so I can see the bios, and what is a cmos jumper reset. Sorry for the ignorance, and thanx again for your help.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 18 Answers
Try and update your bios, hopefully your timings, were just messed up by the new memory, or you could try a cmos jumper reset.
Posted on Mar 03, 2008
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Asus p5ld2 deluxe ranlike a champ until I added 2 additional 1gb sticks of RAM itbeeps whenthe power is turned on but will notboot
it doesn't like the ram obviously,
  • 240-pin DDR2 DIMM Banking: 4 (2 banks of 2)
  • Chipset: Intel 945P
  • DDR2 SDRAM Frequencies: PC2-4200 and PC2-5300
  • Error Detection Support: Non-ECC only
  • Graphics Support: PCI Express x16
  • Max Component Density: 1024
  • Max Unbuffered DDR2 SDRAM: 4096MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR2 SDRAM only
  • USB Support: 2.x Compliant
  • make sure you installed the correct speed of ram, secondly if the ram speed is correct take out one sitck at a time, and try to boot, it's possible that one is bad from factory.
  • If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
    Jan 01, 2011 | ASUS P5LD2 Deluxe Motherboard
    At boot-up I get "invalid
    1) Go into your bios by pressing the Delete key.
    2) Navigate to boot disk priority.
    3) Set this to Primary master disk drive (The drive that your operating system is installed on.
    4) The save and exit.
    This should stop the message from coming up and solve your problem.
    Please rate this solution by clicking on the thumbs up at the top right of this solution, it is much appreciated.
    Thanks.
    Nov 01, 2010 | ASUS A7V333 Motherboard
    Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
    with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
    thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
    post a coment if this does not work.
    thanks,
    wonder
    Sep 18, 2009 | ASUS P5VDC-MX Motherboard
    Asus P3B-F Motherboard
    Download a manual from the ASUSTEK website, I have read many forums related to issue's with ram and from what I have learned with the ASUS boards is that dependind on the bios and the model, each slot, for some unknown reason can only recoqnize a maximum of 128MB per DIMM slot? My board has 4. For example, no matter what I install for Ram the motherboard will only read 512, some of the forums on ASUSTEK reccomend reflashing the bios with an updated one, but now, with the age of these computers i find it difficult to find a Bios upgrade. It is ridiculas, the Bios should come from the manufacturer ready to handle the maximum Ram of 1GB, which is my case with the ASUS P3B-F Pentium 3 with a 850MHZ processor.?????????
    Jun 08, 2009 | ASUS Intel 440BX Chipset P3B-F Motherboard
    I need the manual for my asus motherboard a7v333 rev.2
    The drivers and manual can be found at the link below. They are rather large but if you have a 1gb flash drive or larger you shouldn't have any trouble.
    http://support.asus.com/download/download_item.aspx?product=1&model=A7V333
    Apr 03, 2009 | ASUS A7V333 Motherboard
    EMachine T6534 Ram Issue
    did you try putting 4 1g stick . instead 2 1g and 2 512?
    Jan 16, 2009 | Computers & Internet
    Motherboard ASUS P5RD1-VM ram problem
    More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
    Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
    Feb 16, 2008 | ASUS P5RD1-VM Motherboard
    3x 1GB DDR400 Problem on booting!
    the details for your case can be obtained in this site.....................
    http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
    read carefully to understand the limitations that arise with your motherboard.
    cheers....................
    Jan 22, 2008 | ASUS P4S8X Motherboard
    Unaible to upgrade RAM
    It will only support up to 2GB Ram and the same memory specification
    Nov 23, 2007 | ASUS M2N-MX Motherboard
    ASUS A7V333-X (A7V333-X/L) Motherboard Logo
    178 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
