Question about Sebo Air Belt C2.1 Bagged Canister Vacuum
Sebo Airbelt K1 Electrical Problem
My Sebo Airbelt K1 has lost power due to a bd connection from the supply cable. I'm sure its easy to fix if I could get inside the machine. How can I get inside the cover to fix the problem?
  • VLarcombe May 31, 2008
    I have a similar electrical issue, it started intermitantly and now wont go at all, if I can get to it I'm sure I can fix it.
    I have removed the foam belt and rear clips and the retaining ring on the tube fitting (part 40 on the drawing) but how do you remove the on/off pedal button (part 27 on the drawing)? Im guessing it is a push fit but I don't want to force it.
    TIA.
    Vernon.
    President:
  • 1,673 Answers
Remove the belt or seal that goes around it, there are some clips to take out, then it will separate.
Posted on Mar 04, 2008
Head assembly not working
MOST ROLLER HEADS HAVE AN ELECTRIC MOTOR DRIVING THE ROLLER WITH A BELT AND GETS ITS' POWER FROM A CABLE ALONGSIDE THE WANDS FROM THE HEAD. I SUGGEST A VISIT TO THE MANUFACTURERS WEBSITE TO DOWNLOAD AN OWNER'S MANUAL WHICH WILL PROVIDE ACCURATE INFO SINCE I DO NOT KNOW THE ACTUAL MAKE AND MODEL OF YOUR MACHINE
Jan 01, 2018 | Sebo K1 airbelt Bagged Canister Vacuum
Changing sebo telescopic slide button, how to
go to :http://www.sebo.co.uk/support/downloads/
download your instruction manual, and proceed according with common sense forchange your parts.
God bless you
Jul 15, 2012 | Vacuums
THE BRUSH ON MY HEAD FOR THE SEBO K1 HAS STOPPED SPINNING WHY???
Check the brush roller at each side to see if threads are wound around it. Also, check the brush to see if there are threads wound around it. This is what generally stops the brushes from spinning. It will take sometime to unwind the threads/lint and you may need scissors and tweezers to fully remove all of them but it will be worth it!
Nov 01, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
How to fix sebo air belt k1 hoover
what is the problem first, I need to know before I can help
Jul 29, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
Taking off the bumper from A Sebo K1 Airbelt
First, remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver). The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else.
Apr 10, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
My Sebo AirBelt K1 just stopped working
I work with a Sebo dealer (in the UK), where we repair all makes of vacuum cleaner. It's testimony to the quality of Sebos that in several years I've only had one of this model to repair (so my memory is somewhat sketchy). However, from first principles, the finger of suspicion points to two likely causes of this problem. First, the copper wire may have broken within the flex - this commonly happens where the flex is subject to both stress and tight bending, which is the two extremities (where the flex enters the plug, and where the flex joins the rewind reel). You will need a continuity tester of some kind to check this, of course. The flex may be visibly damaged, but often there's nothing visible externally. Second possibility is that one or both of the motor's carbon brushes is worn out. You will need to get them off the motor to check. Check both - they can sometimes wear very unequally - a new one will have about 2cm of carbon exposable, whereas a worn one can have nothing left at all. As for what's economically replaceable... it depends what you can do for yourself. In the UK a new flex complete with rewind reel will set you back about £45. However, it is possible just to wire in a length of new flex provided you make sure that any connection you make is good, safe and not subject to stress from winding and unwinding. As for the carbon brushes, in the UK they are about £5 each. For a complete new motor you'll not get much change from £100.
I hope this helps. If you need me to try again just post a reply, giving any more information you can, and I'll see what I can do. Good luck!
Jan 13, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
I have a Sebo air belt K1 How do you open the outer casing so as to replace the electric cable.
OK, but be warned... it's not so difficult getting the thing apart, but making a neat job of reassembly has been known to drive grown men to despair. And that's because you have to remove the airbelt. But first things first:
1. remove the hose
2. remove the hose-retaining ring
3. remove the flap that covers the green filter.
4. remove the screw beneath that flap nearest to the handle (there's a deeply recessed screw on the other side, but you can ignore that)
5. remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver)
6. this is where it begins to get interesting. The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The first challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else. (The second challenge is getting it back neatly!)
7. remove the ends of the foam strip far enough to reveal two plastic clips that hold top and bottom of the body together
8. prise those clips off with a screwdriver.
9. it should now be possible to lift the top cover off. It can be a bit fiddly getting it off over the neck where the hose plugs in, but it does come off.
10. the cable rewind spool is now revealed in all its glory.
11. if you've found my advice helpful so far, here's a final piece... don't try to fit a new cable to the old spool - fit a complete new spool.
12. good luck!
I value feedback, so please remember to rate this response.
No power
This is a dead motor. the electrical motor is experiencing windings failure and will have to be replaced or rebuilt. Just to be safe, remove the switch and test with voltage needle to see if the problems here. i suspect total motor failure.
Mar 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Sebo airbelt k1
No screws under the castors. There is 3 case clips, the bumper hides them, maybe this picture will help:
Feb 06, 2008 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Sebo Air Belt C2.1 Bagged Canister Vacuum Logo
422 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
