Pioneer dvr115d i purchased the above fitted to my pc computer recognises it but when i put a dvdr in it still says put disc into drive. just wondering if i put cables in proper its set to slave as was my original dvd re writer be most grateful if any one can solve this problem
    Master:
  • 474 Answers
Now a days you cant really put the cables in wrong becasue they only fit a certain way. but be sure its plugged into the IDE 2 slot on the board and isnt connected on the same ribbon as the HDD. Now it may be a frimware issue, check the website for updates and make sure you have all the driver updates for your Mainboard also. also check the bios to be sure its not turned off, not likely but check anyways.
If you have only one CD/DVD drive, set the jumper to MASTER since its the only one, Or you could set it to CABLE SELECT. And be sure that the IDE cable thats plugged in coresponds to the jumper. I.E. IDE's Master connector is plugged in if the jumper is set to master on the CD/DVD drive. Some mainboards are picky.
Posted on Mar 05, 2008
  • 33 Answers
If you can see the drive then all your connections is fine. I think the culprit is your dvdr disc.Try to use any good disc and see whether it can read or not.
Posted on Mar 04, 2008
  • 196 Answers
Can you see this drive in the BIOS, My Computer or Device Manager?
If not, you need to re-check the cables. If so, it may be defective.
    Problem Solver:
  • 5 Answers
Insert a normal cd and see wether it can read or not, if it display the same message that means your drive is not recognizing the cd, or dvd, reason lens of your cd/dvd unable to read, or your cd/dvd is bad.
Computer does not seem to recognise disc. I keep
Hello !
Either your disk or disk drive is problematic.
Try your disk in another PC to test. If the disk works, your CD drive is faulty. Try another disk in your computer's drive. If the disk doesn't work, you have confirmed that the drive is faulty.
If the drive is a problem, I would suggest to purchase a disk head cleaner, first. Then, if the drive is still a problem, it would need replacing.
Hope this helps.
Sep 10, 2009 | Lexmark Office Equipment & Supplies
Verbatim 4gb flash cant be recognised
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Computer doesn't seem to recognise it - can't open files or burn
This is a pure problem with your DVD drive. try removing teh cable and reinserting it.
May 02, 2009 | Computers & Internet
Dvd writer
Hi.
I stick with Pioneer at the moment. I've had so much trouble with many other brands, but Pioneer drives seem very good at writing even low quality discs which tends to be an indication of a good drive.
Jan 20, 2009 | HP Compaq Presario SR1503wm PC Desktop
DVD+/- Gateway issue DVD won't burn DVDs but plays them
I had the same problem. I finally got a knowledgeable tech at Gateway who knew that a patch had to be downloaded. I'm sorry but I don't have the link anymore but you might be able to find it in there white papers now that you know that it exists
May 16, 2008 | Computers & Internet
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Drive E
does the pc recognise the cd drive , if it does but still not recognise the disk,s then its maybe faulty , replacement dvd drives are soo cheap , £25 ans easy to fit , if you can not see the drive in "my computer" the click start.right click my computer,click properties.click hardware and then device manager.scrool down ,look for dvd/cd rom drives or any yellow question mark???, click item and properties and go from there ,
Dec 12, 2007 | Acer Aspire L100 PC Desktop
LG DVD Recorder problem
is the drive a dvdr or dvdrw? if its a dvdr....rw's wont work
Nov 11, 2007 | Sony (25DPW47LS2/T) (25DPW47LS2T) 4x...
Computers & Internet Logo
93 people viewed this question
Alun Cox
David Payne
David Payne
