Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic 53" PT53WX42F, power board needed
Can someone tell me where I can find a powerboard for my 53" Panasonic television, I have had it for 5 years and now the powerboard has gone out and Tops Electronics says they cant get that board anymore. Can anyone tell me if I can still get this board and where?
    President:
  • 4,402 Answers
You may be able to send the board in check with PTScorp.com, or Tristatemodule.com
Posted on Mar 03, 2008
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Does anyone know what a "d" board is for a 53 Rear projection Panasonic Tv? If so, where can I get one and is it hard to repair on my own?
The D board is the deflection power board the power cord goes to ---not available from Panasonic.
For me to help I need to know what set does or does not do.
This model has a error code, if it tries to turn on and shuts off the power light blinks a sequence---like 3 blinks, pause or 5 blinks pause.
The more you tell me the better I can help.
SD TECH
Sep 29, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic pt53wx42f projection tv will not come on. the power light blinks 5 times
Check resistor R800, it's large white and in the general vicinity of the AC input. You are checking it to see if it is open, if it is then replace. 1.5k 5w. Goodluck.
Jun 30, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Check for open resistor R800 1.5k 5w. It's the big white one by the AC input.
Jun 28, 2010 | Panasonic Televison & Video
Where can i get the projector lamps for a panasonic 53" model #pt53wx42f
i did one and i looked in the yellow pages and found a business in california something called everything lamps co.it only cost 57 dollars and 10 dollars to ship took 7 days and it worked just find put on nitride gloves when you do it.
Dec 02, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Can someone tell me what watt and ohm resistor goes in slot r7006,r7001,r7002,r7003,r7004 for a panasonic pt53wx42f
R7001, R7003, R7004, and R7005 are all 82 ohm 2watt resistors R7002 amd R7006 are 120 ohm 2watt resistors
Jul 16, 2009 | Panasonic PT-47WX49 47" Rear Projection...
PT53WX42F, power light blikns 5 times every 8-10 seconds, tv does not come on
Blown convergence amplifier chips. Very common and expensive repair unless you do it yourself.
Jun 04, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Lizard poop inside non glare screen
all need to be removed to get to the internal inside mounting brackets.
regards,
daniel.
Dec 30, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
