Question about Acer AOpen AW 300 Sound Card
No audio device found, please tell how i install sound drivers.
  • 3 more comments
  • sgupta Mar 03, 2008
    its a PCI card
    Other devices - PCI device - no audio device code 28
  • Anonymous Mar 03, 2008
    NO AUDIO DEVICE FOUND
  • Anonymous Apr 18, 2009
    pci device ??
  • john mc donald May 11, 2010
    is it onboard or pci card
  • 121 Answers
Do you know wat make and model right click on my comp go to properties /device man/ sounds and c wat it says ec. unkown device
Posted on Mar 03, 2008
  • john mc donald Mar 03, 2008
    try taking it out and putting in a dif pci slot and c if it finds it wen you boot back up if not i would say its faulty
    http://scan.driverguide.com/scan.php you can try instal this and c if it can find your device it will let you know if it works hopr this helps
I can't find a audio driver for my notebook aspire 3680
Posted on Dec 09, 2008
3 Suggested Answers
contest25
  • 115 Answers
SOURCE: SOUND DEVICE
http://www.bioticaindia.com/creative-sb-pci128-ensoniq-es1371-sound-card.html
download driver from this link
then install n restart ur laptop
it wud be ok by now
harri
Posted on Feb 11, 2009
SOURCE: Win7 driver for Yamaha YMF753 @SIS 7012 Audio Device wanted
Here's the driver.
Download to desktop. When you update the driver, specify this location and your sound card should work after that.
Let me know/
Posted on Jul 16, 2009
Hi, my laptop is lenovo g550 and when i am trying to install audio driver then its showing the error media device for this driver not found, and even no question mark is showing on the device...
If you run XP SP2 you have to install KB888111 first.
After that (or if you have SP3 already) you need to install driver manually - in Device Manager chose "Update driver" for audio device and chose "I'll load driver manually", then tell Windows to show all drivers and tell you have a disk, navigate to unpacked Audio driver folder where you chose an *.inf-file that contains description of your audiocard. That will do the trick.
http://support.microsoft.com/?scid=kb%3Ben-us%3B888111&x=12&y=12
Apr 25, 2011 | Computers & Internet
When i am installingconxtant audio driver it is telling media device not found and not installing
Typically, if you are getting a "device not found" error upon trying to install an audio device driver, there are a number of issues that could be going on at one time.
First: You may have the wrong device driver or version of the device driver for the device intended for. Check the hardware version number and verify on the website of the hardware device (the audio card if it is an independent audio card that is what you are referring to) what is the latest revision of the driver. Download the driver and install it.
Second: If your device is an external audio card, make sure it's fully inserted into the PCMIA slot (seriel port if being used). If so, then accomplish the following procedure: Power down your PC. Remove the Audio Card and reboot PC. Allow PC to recognize no audio card, then shut down PC and reinstall Audio Card. Reboot PC and install with new Audio Driver
One of the two steps above should rectify the problem. If it doesn't, then the last resort is to assume the Audio card is faulty if it's an external Audio card.
If you have an internal Audio card, then there can be a faulty portion on the sound portion of the motherbood, which then would require the entire motherboard to be replaced. But before you result to this, be sure you have the newest Audio driver for the Audio Codec and installed correctly.
Please keep in mind, Conexant is an OEM supported Audio Codec and you need to refer to the maker of the PC itself for driver support. I.E. it may be a Conexant Audio chipset installed in a HP PC. So, be sure you go the manufacturer website such as "HP" for the audio driver support.
Hope this helps,
Jun 26, 2010 | Computers & Internet
Problems installing sound drivers on my compaq presario v2000
I have the same model,so you are in luck!! The drivers are really actually already there,you just have to tell the laptop(windows) to "look again",so to speak.Just go to Control panel/hardware/device manager,then righ click on any device listed and then scan for hardware changes.You will see "new harware found",then it will tell you it found multimedia device and continue to load the drivers for you.If it`s the same as mine,it will be ATI integrated digital audio,then you should have sound.Please let me know if it works for you:)
Apr 12, 2010 | HP Compaq Presario V2000 Notebook
No sound and voice recording device;not able to get the right sound driver
  • NO SOUND,NO AUDIO
  • check the system - device manager for sound and audio adapter, checks for any markings on the device red x, yellow ? , or ! checks for any sound blaster if not detected (removed it and install back)
  • uninstall and re-install the sound and audio device driver, or
  • install the sound drivers
  • use a headset or external speaker if it works the internal speaker needs replacement
Apr 14, 2009 | Computers & Internet
About sound driver
Try www.hp.com
To download latest drivers.
Jan 27, 2009 | Edirol UA-4FX External Sound System
Sound Problem
usually this means that there is no audio driver. Go to your control panel and open it. than click on sound and audio devices. one the window opens it will say either no audio devices found or it will tell you the what the sound card is. If it does not tell you than you will need to download the driver for your sound card again. If you need any further help with this please let me know. I can get you your sound card driver if you can let me know what the make and model number is of the sound card.
Dec 14, 2008 | Computers & Internet
Audio drives
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Microsoft-UAA-Bus-Driver-for-High-Definition-Audio.shtml
Go to the above site and download the UAA drivers and install them
then go to device drivers and Upgrade sound driver it will go on net to find and install them
Without the UAA drivers your sound driver will not be recognised
I had to do this to my compaq and it found the drivers through upgrade
Please post fixya for me
Aug 30, 2008 | Edirol UA-4FX External Sound System
There is no sound
Try re-installing the Sound Device Driver, you can download the driver here.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=
en&cc=us&dlc=en&product=366264&lang=en
If my solution works, please spare a little time to accept my solution.
-mrsolution
Jun 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
M2N-MX sound
Try reinstalling the drivers, which can be found here.
Apr 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Have no sound device working
You did not specify the name and model # of your computer?
Please add comment with that info...
Oct 26, 2007 | Microsoft Windows XP Professional With...
Acer AOpen AW 300 Sound Card Logo
243 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
