Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
Hard drive failure - Compaq N400
By unhappylady on Mar 03, 2008
have compaq evo N400c, crashed over the weekend and now alternates between fixed disc parameter or BIOS error system halted (on black screen)
or more commonly i get repeated non system disk or disk error replace and strike any key when ready - when I CTRL ALT Delete, i can get prompt back to compaq screen but immediately followed by non system disc error
when i strike any key, or if i depress a key for 3+ seconds get loud bleeps
Is this terminal problem with the hard-drive?
Solution #1
posted on Mar 04, 2008
Not Rated)
dodgecharger
Rank: Wiz
Rating: 82%, 332 votes
Yes, your hard drive may have serious problems. Does the machine have a floppy drive? If so, will it boot to DOS? Or, if you have an XP or linux install CD, will it boot from CD?
Can you hear the hard drive spin up when computer is powered on? Some drives are very quiet, so you might have to put your ear close. Does the drive have an abnormal clicking sound? Western Digital drives were famous for this symptom of failure.
Try swapping the drive into a spare or friend's computer. If the symptoms are nearly identical (no boot), then this points to the drive as failed. Note, that if it does get part way through the boot process, your Operating system (XP, 2000) may blue screen, instead of completely booting. But, if it does get that far, there may be more hope for the drive.
Suggest also you download manufacturer's diagnostic software and run it.
Hard drive failures are very common, some happening within the warranty period or shortly thereafter. This is why backing up your data to CD, flash drive, or other media is so important.
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
How to move large data blocks from one PC to another using Maxtor external hard drive
Answer
when turning on wd 2500bo14 external drive,I get an error message that says usb port is... (More)
Answer
I don't know how to use my Simpletech External Hard Drive. I have the CD and know how to plug it in.... (More)
Answer
can't send info back and forth and it won't eject or unmount. my disk utility says its working fine... (More)
Describe your Hard Drives problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drive Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
