Question about Microsoft Windows Vista Ultimate Edition
Resource meter when I want torun acertian program a warning appears stating that the windows resource is to low how do I increace it
  • 152 Answers
It is stating the virtual memory.... what program is it and how much RAM do u have bcoz it would mostly be the RAM... rarely for the case of a high graphics program it would be the graphics card memory....
Posted on Mar 03, 2008
Acer 5542 freezes
You can start by checking the Event Viewer. Right click My Computer / Manage. Check System for Errors and Warnings. They can be very technical, but most likely there is some event. Check Application as well. There is a Filter option under View. Leave Warning and Error checked.
A helpful tip.
Slow Windows Machine! Sounds like not enough resources such as RAM and CPU. Check Performance in Task-Manager (CTRL-ALT-DELETE). Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 06, 2012 | Computers & Internet
I have an acer aspire 4736g, i need to restore my notebook to factory default, i wait for the acer logo to appear on the lcd screen. then i press the "Alt" and "F10" keys at the same...
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Resources
Acer Website
Mar 01, 2011 | Acer Computers & Internet
Ssss
Trying to run too many programs at the same time can cause display problems such as jittery or choppy video. If you notice erratic or reduced visual performance on your computer, try one or more of the actions described below.
1.The more programs you have open, the more system resources Windows needs. Try closing programs that you're not currently using, or reducing the window size.
2.Even if you have only a few programs running, some programs (such as video-editing programs) and features (such as high-definition television) use a lot of system resources. Running too many of these programs at the same time puts a strain on system resources and might degrade display quality or make video appear jittery or disconnected.
On some computers, very high resolution require a lot of system resources to display properly. If you notice problems at high resolutions, try lowering the resolution until the problems disappear.
1 open display from control panel
  1. In the left pane, click Adjust resolution.
  2. In the Resolution list, click the resolution you want, and then click Apply.
If you set the DPI higher than 96, and you're running the Aero desktop experience, the text and other items on the screen might appear blurry in some programs that aren't designed for high-DPI display. To avoid this problem, follow these steps:
To make text and on-screen items clearer in programs that aren't designed for high DPIIf you set the,
  1. In the left pane, click Set custom text size (DPI). ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In the Custom DPI Setting dialog box, select the Use Windows XP style DPI scaling check box, and then click OK.
Dec 11, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
How do I uninstall hpassistant.msi files?
  1. Download the Windows Installer Clean-Up utility (see Resources forlink). Click the link on the download page on the Microsoft website andsave the file to your Windows desktop.
  2. Double-click the utility setup icon on the desktop. The icon is labeledmsicuu2.exe. Follow the prompts and the installation wizardinstructions to install the utility. Click the "Finish" button in theinstallation wizard when it is finished.
  3. Open the utility. Click Start > All Programs > Windows InstallerClean-Up. This opens the Windows Installer Clean-Up window.
  4. Click to highlight the program whose MSI files "HP ASSISTANT" you want to remove, thenclick the "Remove" button. This opens a warning prompt window.
  5. Click the "OK" button in the warning prompt window. The utility will remove the MSI files for the "HP ASSISTANT" application you selected.
Regards,
Rizwan
Jan 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
An alarm goes off if I have more than 2 progs running at same time,ie: if I am on facebook and making cards at same time My C drive holds 223gb and i have 104gb empty.
I don't think it's hard drive memory that is causing you trouble but system ram memory. Open control panel and go to system and on the first page that pops up it should tell you how much system ram you have. You should have a minimum of 512 megs. XP and Vista recommend at least 512 megs of ram and would rather have 1gig. Another thing that can lead to this problem is how many programs are starting up automatically when you boot up your system. Every program that starts up uses system resources. When your system resources drop so low then you will get a warning or programs won't run right. System resources are partially determined by the amount of ram memory you have. Click on "Start" > "Run" and type in "msconfig". Hit "Enter" this will pop up a new windows. Click on the "Startup" tab. Listed there are all the programs that start automatically. Some of these are required by Windows but many aren't. By unchecking the box next to them you will keep them from loading each time Windows starts. Be careful disabling these. Best to expand the command line and you can google the name of some of these startup files and find out what they are and if you need them. Try disabling one or two at a time and rebooting. By knowing what programs to allow to start and getting rid of the rest of them, your computer will run much better. Hope this helps.
Dec 20, 2009 | Office Equipment & Supplies
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I have a website that is showing a Warning Message on one of the profile creating pages stating: Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/thelan8/public...
Hi,for your website required good hosting ,for that use this http://www.tucktail.com/ site,here also SSL certificate , domain names ,various free service also available at very low cost.
Sep 27, 2009 | 2004 HM CRM 125
Driver for e-binocam in Windows Vista won't work
20 Apr 2009
I was just on the Digitech website looking to purchase a digital binocular camera and saw that they (advertise) state their equipment will NOT work with Vista.
sorry I couldn't provide a better solution for you.
Feb 20, 2009 | NADEA Mini Gadgets / Naxos eBinoCam eB3200...
Level Warning
battery level. charge it or replace it if it does not come up to full power state. the camera has a batter meter. refer to the manual and see if the battery is low. it requires you to push a few buttons while looking at the data window.
not really difficult.
the battery that might be dead or extremely low is the small battery that keeps the date etc, which is much like a large watch battery.its usually coin shaped, but on some models its a small version of a aaa battery only slimmer and shorter. not sure which that unit uses now.
if these are both ok, then you probably have a service issue
good luck
mark
Dec 12, 2007 | Canon Digital Rebel / EOS-300D Digital...
Turn sound off
- In the tray bar its an icon for the printer, you click there and a submenu where the printer name appears, click the submenu and a window will popup. - In this window, go to options menu and you'll see the first options submenu (state options or something like that, not the cleaning option) - And there you'll find a "Sounds" section where you can choose to hear all, warnings or nothing. And that is all. If you cant find the tray bar icon, then you can go to start, programs, find the canon Laser Shot LBP-1120 folder and find the State Window Shortcut, the icon will appear in the tray bar now.
Sep 19, 2007 | Canon LBP 1120 Laser Printer
Microsoft Windows Vista Ultimate Edition Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
