Question about SanDisk Sansa e200 MP3 Player
My screen is screwed
I turn my player on and it starts up like normal but after a second the screen disaprears and is replaced with lines. is there anyway i can reset it or something?
  • 3 more comments
  • Jimbob91 Mar 03, 2008
    ive looked all over it for a reset button. where abouts should i be looking?
    thanx heaps. it worked.
  • gillden Mar 04, 2008
    were is the reset hole???
  • scrappy1313 Jul 24, 2008
    WH3R3S TH3 R3S3T BUTT0N?
  • BBBOPPER Nov 17, 2008
    The reset hole isnt there what do i do?
THER IS NO HOLE
Posted on Nov 17, 2008
Where the hell is the hole on the side
Posted on Mar 05, 2008
  • 121 Answers
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE!!
AND FORMAT THE PLAYER just a small hole!!! if this dont work your screen is faulty
Posted on Mar 03, 2008
  • 790 Answers
AND FORMAT THE PLAYER ... GUESS PLAYER HAS INFECTED BY VIRUS!!
  • Kanth raj
    Kanth raj Mar 03, 2008
    Its not button ... just a small hole!!!
Vertical lines on screen, screen starting to white out
This can be one of two things that I can think of. First try hooking up your laptop into a different monitor. If the display will turn on and looks normal on second display, then your display in your laptop needs to be replaced. But if the second display does not work than it is possible that your video card may need to be replaced.
Aug 15, 2013 | Computers & Internet
White screen', wont turn off to restart and computer doesnt recognize the player
YES...! After holding switch in up pos for 10 seconds, it went dark. Then I performed normal start up of Fuze (Holding switch for 1 2 seconds and it started up normal with display and is now recognized.
This problem ocurred when I left the unit plugged in to USB and closed lid of my laptop overnight. ( Laptop set to go into suspend mode)
Great help, thanks.!
Jul 16, 2010 | SanDisk Sansa Fuze MP3 Player
How do I change battery on my mp3 player
with a creative zen v plus, it's gonna take a little time and some prying, but it's fairly easy. First, snap off the bottom piece where the play and return buttons are. underneath should be the contrast color piece. then, take a small screwdriver and carefully remove that contrast piece. it should snap off. when that's off, the top will look the same but you should be able to see the motherboard. In the right corner there's one screw you'll have to take out to get to the battery. but first, the screen. this is where the prying starts. you need to get underneath a little all the way around, and pry it off bit by bit. it took me about ten-fifteen minutes to get the screen loose without damaging it. it's still attached, but when you lift it you'll be able to get at the second screw. once both screws are loosened you'll be able to lift up the motherboard and screen to get at the battery. the volume control cover piece just falls out but just replace it before you put the screen down again. the battery is stuck down, but just disconnect it from the motherboard (there's a little white plug ) and pull it off. replace the battery, and when you put the motherboard back in, lift the screen a little so the usb port, line-in, and headphone jack can slide into the holes. replace the screws, press down the screen, and snap the contrast and cover pieces back in. you're done.
i don't recommend doing this too often, as the screen will become really loose. be really careful, and make sure not to hit anything with the screwdriver. good luck!
Nov 01, 2009 | Creative Labs ZEN V Plus MP3 Player
My Insignia Sport will not turn off
on the back of the player there is a small black dot toward the top of the battery cover remove it to reveal a small eyeglass type screw remove it with an eyeglass repair kit or a straight razor remove the battery cover very gently there is a small wire attached to the battery at the bottom of the wire is a plastic prong with your fingernail gently pull the prong away from the player wait a few seconds and replace it press power and your player should start back up
Aug 18, 2009 | Insignia Sport MP3 Player
It seems i have over charged my sand disk player so right now when i switch it on it says battery too slow and then it shut down it self, please i need a help to this problem .
Hi teddyabout,
There are few reasons your SanDisk Player is acting up. Here are some things to try out.
Make sure the HOLD switch is turned off before you power up your player. This will sometimes cause errors in booting.
If that doesn't work you can try a soft-reset by holding the power button down for 15 seconds then try turning the player on normally again.
Finally, if you are brave enough, you can take the battery out of the player to force a complete reset of the player and battery. This is done by taking the four screws out of the back of the player and removing the battery. After 30 seconds, put the battery back (be sure the it is seated properly) and replace the screws.
Good luck
-SHG
Jan 14, 2009 | SanDisk Sansa e200 MP3 Player
Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
Microsd makes Sansa e280 screw up
Reset your player by slide and hold the power button for 10 seconds.
if that doesnt work let me know!
Mar 27, 2008 | SanDisk Sansa E280 MP3 Player
It's frozen
ok first off, you need to hold down the power/menu botton for about 30 or so seconds. this will trun it off. then wait a few seconds and turn it on like you normally would. now it should work properly. if that ever happens again, just repeat these steps =)
Feb 18, 2008 | SanDisk Sansa e260 MP3 Player
White Screen.
unintall the device from the computer and try to reinstall it again..if that doesnt help you you will have to get a new new device from sandisk...
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
Left connected when shutdown
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Apr 12, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
